bigshot
Makes no sense. And the ferocity they grab on to the foolishness makes even less sense.
You have mentioned a specific value in your excruciatingly long message.....
I can’t remember where but I recall that 10dBSPL is roughly the noise output by a 100w incandescent light bulb. Of course, you’ve probably never heard that noise because it’s roughly 30 times below the noise floor of an average sitting room and roughly 10 times below the noise floor of most commercial studios. The only place you would likely be able to hear it....
G
Again, what is the science of the incandescent lamp (filament(?) buzzing?
What are the numbers to arrive at 10 dB?
Would the level of the factual support, quoted above, true for all your statements: " I can't remember" but "you've probably never heard".
We are taking science here, not the vague recollections and personal reflections, right?
How different then your statements here are from the cable worshippers talking about" cleaned up" treble, "punchy" bass and tremendous euphoric enhancement? ;(
I asked simple factual science questions to be answered based on the statements in the comments.You aren't "taking science here", you're throwing a bunch of random things you don't understand against the wall in the hope that something might stick.
Continually harping on the red herring you created around buzzing lightbulbs isn't helping.
I am continued to be amazed by the level of personal attacks and irrelevant comments that fully reveal the level of "scientific relevance" of many posters in this thread.
I do continue to count the words needed to answer a specific question on 10 dBSPL of the 100 W incandescent light bulb
That sums up well your level of the factual relevance. Thank you for your contribution to the word countYou invented a contrived and irrelevant question in an attempt to derail actual discussion.
Really, you can’t tell the difference?How different then your statements here are from the cable worshippers talking about" cleaned up" treble, "punchy" bass and tremendous euphoric enhancement? ;(
The clear similarity is that the example of a 100-W lamp and cable claims are both factually non-supported statements.Really, you can’t tell the difference?
I was obviously using an analogy, I’m obviously not claiming there is an actual 100w incandescent light bulb inside every DAC, I was just using it as an analogous SPL to give some perspective. If the SPL I gave for the bulb is wrong, it doesn’t invalidate my point, just substitute something else that does produce 10dBSPL.
This is different from cable worshippers talking about cleaned up treble or whatever because that’s not an analogy, that’s their actual claim.
Do you really need this obvious difference explained to you?
G
It seems you have an assumption that incandescent lamps produce a buzzing noise....and are asking this community why. The only definitive buzzing I've heard from a standard incandescent bulb is when it's burning out, or I tap it and hear the filament (whole or broken) vibrating. So electricians do say that an incandescent light bulb can buzz if it's operating on a dimmer: IE: it's being regulated from its intended watts. Otherwise, I'm old enough to have spent over half my life with incandescent bulbs, and I don't remember noise. Florescent bulbs, though....that's all I remember.Again, what is the science of the incandescent lamp (filament(?) buzzing?
I would believe that for full current incandescent (because 10dB is so small). I do remember as a kid that our house had a dimmer for the dinning room chandelier. When you were rolling it to the lowest dimness, then you did hear buzzing. I'm only bringing up because it's the only accepted scenario I can think of for buzzing incandescent bulbs.Gregorio said he read that incandescent bulbs put out a buzz at 10dB. I don’t doubt that. 10dB is very small, and it would never be audible in the real world. I don’t think phonophi has any idea what the numbers represent, so he’s putting undue emphasis on things that don’t matter.
No that’s NOT the similarity! We don’t dismiss cable claims only on the basis that they’re not factually supported but on the basis that they contradict scientific theory AND directly contradict both countless objective scientific measurements and numerous well controlled double blind tests AND, on top of all that, the claims are unsupported!The clear similarity is that the example of a 100-W lamp and cable claims are both factually non-supported statements.
Presence of such statements unvalidate the credibility and the very scientific rigour of any presented arguments.
No, I’m not referring to dimmers, some of which are very obviously audible and probably go up to 50dBSPL or so. I was referring to just the bulbs themselves. And, there most certainly is an “accepted scenario” in which a 100w incandescent bulb would generate noise, in fact, according to the science, it’s unavoidable. Nyquist/Johnson noise, also called Thermal noise, is present in all electrical circuits and increases with temperature. Thermal noise is commonly the limiting factor of DACs even at room temperature and obviously a 100w incandescent bulb gets very much hotter. So 10dBSPL is certainly a believable figure even though it may (or may not) be incorrect.I'm only bringing up because it's the only accepted scenario I can think of for buzzing incandescent bulbs.
