Is there a recommended cleaning method?Hi, yes, it may need to be cleaned up in time.
DAC and Headphone Amplifier · Streaming Media Receiver · Local Playback All in One Unit, FIIO K17 Is Officially Released!
- Thread starter FiiO
I'm considering an all in one option. I've been interested in this K17 or the K9 AKM version. I can find the K9 AKM on Amazon US but not Canada. I cannot find the K17 on either site. Unless there are other really good all in one options out there.
LakeOfTheWyles
Depends on your use case and budget. There are a number of options, but nothing quite as feature rich as the k17. Haven’t heard myself yet so I can’t speak to SQI'm considering an all in one option. I've been interested in this K17 or the K9 AKM version. I can find the K9 AKM on Amazon US but not Canada. I cannot find the K17 on either site. Unless there are other really good all in one options out there.
FiiO-Yellow
Sponsor: FiiO
Hi, sorry, K17 was a hot seller and is now out of stock. I think we still need to wait about 3~4 weeks.I'm considering an all in one option. I've been interested in this K17 or the K9 AKM version. I can find the K9 AKM on Amazon US but not Canada. I cannot find the K17 on either site. Unless there are other really good all in one options out there.
Farli
It's just a shame it has no DLNA support. It would be perfect unit. I'll give a try anyway. Combination with Wiim Pro might work.I'm considering an all in one option. I've been interested in this K17 or the K9 AKM version. I can find the K9 AKM on Amazon US but not Canada. I cannot find the K17 on either site. Unless there are other really good all in one options out there.
Xinlisupreme
Is Roon best way to get max SQ ?
I suppose using it with AirPlay or BT connection you can’t have the best sound right?
I come from an XA02 that I would upgrade
yes, ROON will be better in SQ and easy to use.
DLNA is not so stable , we dont wnat to have so many complain about DLNA , we had tested lots of device which supports DLNA but all is good enough to installed in K17.
Wifi password with special character still doesn't work.
Additional info. Current network encryption is on WPA2/WPA3 Personal. I switched to pure WPA2 Personal (while using the same password with special character) just to try if the K17 will connect, no good - still won't connect.
BT pairing mode (straight out of a Reset All) - still doesn't go to pairing mode!
K17 at one point was stuck on PO+PRE and UH
Even after multiple Reset All - still stuck at PO+PRE and UH. This is when I also noticed that BT pairing mode doesn't work.
I had to turn off the unit using the AC power switch. This is the only time the unit was back to normal operation (I'm on PO and M)
@FiiO
With all the feedback I'm giving your team, I'm looking like part of your beta tester - CanJam SG is coming up - I should get some token from you for doing this!![]()
@JamesFiiO
I hope you guys can fix the unit being frozen at PO+PRE and UH
And for the K17 to connect to Wifi with special characters in its password
ROON is expensive, any alternative?yes, ROON will be better in SQ and easy to use.
If the Roon monthly fee would include Tidal, Apple Music and Qobuz, it would be OK…ROON is expensive, any alternative?
@JamesFiiO
sure we will.
julien-hifi
Hi,
Just got mine. And can’t find the menu to connect to wifi…
By the way for those interested I posted a detailed review of the K17:
Overall I think the hardware is magnificent but it does need some firmware fixes ( it is freezing for me in a few places where I have to switch it off on the back ) and software updates (FiiO Control and the Custom PEQ editing capabilities). With Roon is is fantastic but it is a pity there are not more streaming options.
Pros: Exceptional Hardware and Build Quality - aluminum alloy chassis, tactile physical controls, and a high-resolution 3.93-inch touchscreen.
Retro aesthetics with modern functionality.
Dual AK4499EX DACs, 4000mW per channel balanced output, and a discrete Class AB amplifier
Lots of Input and Output Options (USBx3, RCA, coaxial, optical, XLR, 4.4mm) and wireless (Bluetooth, AirPlay, WiFi)
Roon Certified and with other some decent streaming capabilities (Airplay, local usb playback)
Cons: Maybe a bit big for some home desktop setups
I would like more streaming options (DLNA, Tidal Connect, Spotify Connect, Plex)
FiiO’s Retro revolution continues with the outstanding and updated K17
FiiO has been at the forefront of the modern “retro” audio movement, releasing nostalgia-inspired products such as the CP13 cassette player and TT13 turntable. With the K17, FiiO integrates this classic aesthetic with the...
- jeromeoflaherty
- Comments: 6
Farli
I'm sure I will give it a try. Still waiting to be in stock here in Czech Republic. Currently I have Matrix Audio Mini-I pro 4, which I like very much but mising EQ. Looking forward to compare both units side to side.
Total: 14 (members: 4, guests: 10)
