I now have the CX in my system. I had a long listening session last night. It didn’t take long to notice that the combination is clearly quite a significant step up from the stand alone EX. I have read some posts on other forums that the CX doesn’t bring much if you mainly stream music from Tidal etc. I completely disagree, since 99% of my listening is Tidal now.
I am using a Supra ethernet cable between EX and CX for now while the Antipodes cable is getting burned in between my modem and wifi router (based on recommendation from
@Clive101 since I have his old CX and he hadn’t burned in this particular cable). After 2 months I will swap the cables and report back.
There is no documentation on how to swap a Roon core from an EX to CX so here are some tips based on recommendations from Mark at Antipodes:
1. Install a new SSD in the CX and add to storage in the antipodes.online interface. I used a disk of identical type, but not sure if this is necessary.
2. Power down both CX and EX, then remove the disk installed in step 1 and replace with the disk from the EX.
3. Fire up both machines. In the settings delete the Roon core from the EX.
4. In Roon remote select the new Roon core on the CX, enter passwords for Roon and Tidal etc. Restore your latest backup.
Mark warned that it is important not to skip step 1. If you just add your EX disk in the CX and then try to add this disk to storage it will delete the contents of the disk!
To be extra safe you can make a copy of your EX disk after step1. This is a royal PITA. My tiny 150Gb library took a day to copy and at the final stage I get error message that some files couldn’t copy because of .DS_store files. This then requires going through hundreds of albums one by one to find the missing files!
For now I am leaving my setup as Roon on CX and HQPlayer on EX. I am probably missing the last fraction of sq, but don’t really enjoy faffing with computers much.
