CX, EX, K, S, Oladra, Antipodes, Owners Unite
- Thread starter Clive101
richardloh
- Mar 19, 2014
https://www.google.com/search?clien...2cHHcskCxQQBSgAegQIEhAB&biw=360&bih=665&dpr=3Direct Stream Port
Network Output Port
Why name these network ports when they seem to do the same. I can access the Dashboard using either of these ports when connected to the network so no direct ethernet connection between CX and EX is being used?
I understand what each port is supposed to connect to but it makes no difference which port you use. You can still access the network and the Dashboard. From my findings they are just two Ethernet ports with no difference.
- No direct network connection: The EX does not have a direct connection to the network; it relies on the CX for all network functions.
richardloh
- Mar 19, 2014
Lower noise is only difference ? Nothing said that as they are different as ethernet ports right ?
It says no direct ethernet connection but to cx as server when used as a stack which is certainly not wrong but it also did not say each cannot be access right ?
Btw, what is your point or concern if any ?
Cheers.
Cheers.
Connecting CX and EX to a Network switch so no direct link just the CX and EX seperate on the network is why I am asking. Mark says to use the network ports but if the Direct ports give lower noise surely those are the better option?
richardloh
- Mar 19, 2014
To me .. cx as server requires input of "network" port 1 and as such default "low noise" "direct" port 2 to ex player's input of "network" port 1 .. I had not tried to ex input of "low noise" "direct" port 2.
Maybe .. just maybe this "low noise" "direct" port 2 is only matters i.e. low noise as an output "feed".
I also do not know why you should want to connect both cx and ex directly to a switch of unknown performance and added device that is not developed nor tested by Antipodes to expect better performance to just ex player directly to cx server in close proximity of shortest possible ethernet cable.
Cheers.
Cheers.
Progisus
I agree. Why label them differently if there is no operational or electrical difference. I doubt Antipodes will clearly explain this as it is audio magic. I have a K30 and do use the direct stream port to connect an EX I have. I can’t say there is any audible difference between the direct stream and another upstream switch port for connection of the EX other than convenience.Connecting CX and EX to a Network switch so no direct link just the CX and EX seperate on the network is why I am asking. Mark says to use the network ports but if the Direct ports give lower noise surely those are the better option?
There just network servers with two ports on theres no magic on either of the ethernet ports.I doubt Antipodes will clearly explain this as it is audio magic.
That's my thoughts anyway.
richardloh
- Mar 19, 2014
So it seems there is an improvement in the sound using Direct Port according to Christiaan Punter of Hifi-Advice. Mark Cole said to use Network Ports if connecting both to a Network Switch.
I will have to do some critical listening myself when I get the Audio Network Switch to see if I can hear any improvement between the Direct and Network ports.
richardloh
- Mar 19, 2014
No .. improvement is using cx and ex stack connected via direct port #2 of cx's output to network port #1 of ex .. like myself and as advised by founder, designer and boss of Antipodes, Mark Cole, .. instead of both separately to network switch. Cheers.
Direct compared to existing Network did he use a decent Network Switch when connected to existing Network in his review of the CX+EX?No .. improvement is using cx and ex stack connected via direct port #2 of cx's output to network port #1 of ex .. like myself and as advised by founder, designer and boss of Antipodes, Mark Cole, .. instead of both separately to network switch. Cheers.
richardloh
- Mar 19, 2014
To me, keyword is output of direct port and sure, ethernet ports are bidirectional but why mix them and Antipodes does not know this and add cost with 2 ports as intended ? No further comment from me on this unless I tested my setup against Mark's advice to find improvement but no intention to do so or perhaps my setup does not have the resolution to show any difference either ways. Cheers.
kennyb123
There is likely a difference but Antipodes likely keeps quiet about it to not give their competitors any ideas. They are similarly hush about most of their implementation decisions. The biggest mystery is the tuning they say they do to each of the boards. I’d love to know what that entails but I’m sure they will never disclose it publicly.Why label them differently if there is no operational or electrical difference. I doubt Antipodes will clearly explain this as it is audio magic.
It’s commendable that you listen for yourself. The only thing that matters is what matters to our own ears.I can’t say there is any audible difference between the direct stream and another upstream switch port for connection of the EX other than convenience.
richardloh
- Mar 19, 2014
Total: 8 (members: 0, guests: 8)
