Clive101
- Dec 27, 2016
Hey all.
Question 1: I am looking at replacing my (normal Win10 PC connected via normal home networking) Roon Server with either a CX, or a Nucleus+ (which I will locate on the stereo rack). Given that I am running through an EtherRegen into the EX, I am hoping the that sound quality differences between the two would be smallish or nominal. If you have experience with that kind of difference I'm happy to hear it.
Question 2: Given that a used Nucleus+ is roughly half of a used CX, what are the functional differences between the two? i.e. I know you can run HQPlayer and such on a CX. You can't do that on a Nucleus+ right? And of course you can run lots of rendering apps on the CX but I wouldn't as the EX is here already.
Question 3: I have the perception that administering / updating the Nucleus+ is simpler / better integrated. Any downsides or upsides I should know about using the CX as a server?
..Just trying to figure out if I save the money and reduce complexity with the N+ vs CX without giving up anything I care about.
Sorry for the blunt answer as this is a no brainer.
I would go with the CX EX combo, no need for network gear sell it use the standard ethernet cable with the EX or CX if you can get hold of one.
You may get a second hand CX for a good price which will make the upgrade a bargain in terms of SQ as the newer Antipodes come online.
You cannot compare the SQ upgrade when you add CX to your EX or vice versa with a Nucleus.
I would strongly recommend the Combo as an upgrade for the above reasons.
