kennyb123
It’s clear to me that the AMS 5 update improved sound quality. It appears to me that some grunge was present previously that’s now gone. This has made both great and poor recordings are easier to listen to and enjoy.
Both cx and ex can direct stream to your dac. Although your library is not large, I would suggest the cx as it can handle large libraries and also has the upgraded computer with the instruction set needed if you wanted to experiment with hqplayer. I used the ex as a roon server and player but often had slow downs when searching on roon. It makes a top grade player though if you need the usb.Guys, for someone new to all things Antipodes, what's the best entry route when moving away from NUC? I'll be using ethernet / no USB, Roon preferred, small library (<2TB). From an hour reading on the net, CX standalone is the go to for direct ethernet to DAC or is EX laso capable of this? Any steer would be greatly appreciated.
Excellent advice.Both cx and ex can direct stream to your dac. Although your library is not large, I would suggest the cx as it can handle large libraries and also has the upgraded computer with the instruction set needed if you wanted to experiment with hqplayer. I used the ex as a roon server and player but often had slow downs when searching on roon. It makes a top grade player though if you need the usb.
See what this reviewer said about the K41 used as a server in this review. This will give you an idea of what you'll hear from a CX used the same way, though the K41 will of course deliver a lot more.Always up for trying something new but I've always been a bit sceptical of server hardware making a difference to SQ over ethernet. Guess it does otherwise you guys wouldn't be here or Antipodes!
I have only seen positive things mentioned when an additional device is added that can allow the Player app to run on a separate device from the Server apps. The only question is whether you should wait for a more powerful Antipodes device to emerge, such as an S40 or a CX. I believe that will depend on the size of your library. If the S30 seems to be okay hosting your library presently, you should be okay for the time being.Now there’s the opportunity to add an EX to the mix and I am wondering whether that’s a good idea or not?
On the Antipodes owners forum I have been reporting my thoughts on the Server and Player app combinations available through the recently released AMS 5.0 and I copy my musings here as I am pretty blown away with what I have been hearing.
I set aside an hour and methodically worked my way through all the Server and Player app combinations including purchasing a HQP 5 upgrade license. For this I listened to a track called Toccata and Fugue in D Minor from the Jacques Loussier Trio album (see picture below) and after this session I was left in no doubt that all the other combinations of Server and Player apps are some way behind Squeeze + Squeeze in terms of sound quality.
The piano at the start of the track is a fantastic test. It is easy to forget that piano is a percussion instrument and when heard live it can have quite an attack to the notes. Squeeze + Squeeze makes the track sound like a real piano. None of the other app combinations do that.
Then there is the double bass. With Squeeze + Squeeze there is so much detail and shape to the notes. Unfortunately with the other apps the double bass notes can easily become just a shapeless thump.
With AMS 5.0 it is very easy to switch between Server and Player app combinations and I strongly suggest that it is worth setting aside and hour to do that. The first two or three minutes of the track played with each combination should be enough to make up ones mind.
Roon is obviously mentioned quite often in the context of sound quality. Roon Server and Squeeze Player in my opinion is in the ‘not bad’ category. But the obvious smearing of mid range notes is a disappointment after Squeeze + Squeeze.
All my listening for this was using the BNC output from the Oladra2 to a Chord Mscaler connected to a DAVE Dac (with SJ ARC6 power supply) and that is connected directly to ATC 150 Active speakers. I don’t own any headphones. Also I am listening to locally stored files on the Oladra SSD because I marginally prefer the sound compared to streaming the same files from Qobuz. My Oladra2 is connected to my local network using an Innuos PhoenixNET switch. Everything is powered through a Puritan 156 and everything is earthed with the Puritan Ground Master system with external earth rods.
Hello Nick,Puritan 156 and everything is earthed with the Puritan Ground Master system with external earth rods.
Hello Clive, I like what they do a LOT! Thank you for suggesting them in conjunction with the Puritan Groundmaster. It was actually quite a task to get the rods into the ground to a good depth (two rods, both 8ft deep).Hello Nick,
How did the ground rods affect the SQ ?
Regards Clive
Isn’t that was used before your G4 upgrade?My next task is to try a 3 voltage rail LPS to power my Oladra Instead of the factory smps! I have an itch that I want to scratch.
I suspect that he is referring to use of a Sean Jacobs power supply.Isn’t that was used before your G4 upgrade?
No, the Oladra has always had a smps.Isn’t that was used before your G4 upgrade?
Ended up coming g to a decision that K22 was the way to go for me but trying to find one in the used market is like a needle in a hay stack. Spotted a new listing for a G3 K50 yesterday morning that was a good deal so that with a Jorma AES are heading here in the next day or two. Quite looking forward to hearing this especially after watching the interview with Mark on YT last night, seems like quite a grounded guy with good design philosophy!Both cx and ex can direct stream to your dac. Although your library is not large, I would suggest the cx as it can handle large libraries and also has the upgraded computer with the instruction set needed if you wanted to experiment with hqplayer. I used the ex as a roon server and player but often had slow downs when searching on roon. It makes a top grade player though if you need the usb.
