buonassi
So I'm not as well versed at custom fitting as others here, as I only have 2 CIEMs now. But I think my F7 may be a bit loose. At least compared to my F-Black, it's quite a noticeable difference in fit. I haven't really lost any weight so I'm not sure if the F7 is too loose, or the FBlack too tight? Hopefully you guys can help me understand if what I'm experiencing is OK, or if I need to send them back for a 'thickening':
I know, lots of questions. Just want to get your guys' opinions before I bug Piotr or his great staff. Thanks in advance!
-Vince
- I can achieve a seal, no problem. But it tends to break easily. When I'm walking about and turning my head, for example. Also, I can't lay down on my back without the seal breaking, but I think this is normal?
- If I'm sitting up or reclining moderately in my recliner chair, and not twisting my head from side to side they are very comfy and seal great! For this reason, I'm beginning to think that this is the preferred audiophile fitting based on comfort?
- The Fblack may have been 'coated' after printing from the 3d printer, which would explain the extra tightness. Is it possible that my ears have 'stretched' because of using the FBlack with its tight fit?
-Vince
