thelostMIDrange
- Nov 1, 2011
a couple hours listening to the raw wood inner/shellac outer...it's not it. everything is fine, even sounding, true instruments, natural. no obvious defects, but it's a little too dry sounding. It's missing some element of mystery and fun. missing a touch of compression and 'give' in the midrange. i.e. opposite of dryness.............
found something..
it's the tru oil that brings out the ortho type mid compression in the driver. 'bloom'.......apply with rag. wait 4 hours, use the scuff side of a slightly damp sink sponge to wipe a few times around followed right away with a t shirt to wipe up some slurry and spread the rest around smooth....
final feel is very thin oil/wood look
sounds rich and musical. instruments are still true and natural. the oil also brings out the upper end character...that was the trick and what the other finishes couldn't do..... totally different than the dry raw wood sound inner. And it takes a total of 5 minutes in actual time to transform the sound....the finish matters. you can change the entire character of the sound with just a thin application to the inner walls. amazing....the problem is the bass gets less defined......
found something..
