dongster
- Aug 23, 2016
resonance can do that. think about blowing into a bottle, if you add water to change the volume of air inside it, you change the frequency at which the bottle resonates. by inserting the IEM deeper you change at the very least the volume of air in the ear canal/IEM system. that's only the super obvious stuff.
the measurement rig obeys the same rules, but it's not so strange that a perfect cylinder and some more or less arbitrary distance between the IEM and the mic, will end up showing something very different. maybe we just assume the spike shifted because we see/ear 2 spikes and assume they must be the same thing. but your ear is not Crinacle's coupler.
again as others have said, of course we wish to correlate measurements and our impressions, I'd like that too. but most of the time we are talking about 2 different systems and conditions and there is only so much to correlate without making false assumptions. the purpose of those measurements if to tell when one IEM has a lot more trebles than another one. measurement compared with other measurement done the same way with the same rig. then because you've heard one of the IEMs, you can start making educated guesses about how the other might sound to you. that rational is pretty solid. at least more than a direct measurement to feeling conversion attempt based on 1 graph and some arbitrary compensation.
Addressed this observation quite early on in the thread here. Deeper insert results in higher frequency resonant peaks shifting higher, while a shallower insert results in a shift to a lower frequency. This is not limited to DIY tube-based couplers and even ISO-standard couplers need to take this into consideration.
thanks for the responses
was just wondering if there is some effect other than resonance
