Does the X7 headphone output sound better when set to High Gain or am I going deaf? Anybody else noticed this?
I noticed this with my K612 on both my X7 and E5. There was more than enough volume on the K612 in low-gain, but I figured why not try. On high gain, the K612 sounded fuller, more lively/euphoric, while having less excursion issues.
It's important to match gain with the headphone. At RMAF, the HiFiman attendant told me that we couldn't hook up the much more sensitive Edition X to the same amp as the HE-1000, even if we got the right balanced connection, because the amp was too powerful for the Ed. X and would damage the drivers (and my ears).
I know some devices, especially portables, boost gain by uncapping a voltage threshold, therefore able to get louder but sounding more grainy in the process. The amp still only had the same amount of current to output. Some devices, the amp is so loud natively that (still learning this, please add info if you know or I get terms mixed up) the amp has to use a negative feedback loop to cancel out some of the amp energy to keep the audio from being too loud... Which is why you see receivers (and their huge amps!) listing a negative number that gets closer to 0 as you turn up the volume. I think (could be wrong) that the reason my K612 sounds better at similar listening volume (I start from quiet and I turn up to listening) is that in High gain mode, it uses less negative feedback.
I could be wrong about all that! I am no electrical engineer, just an enjoyer, so feel free to wiki-search "amplifier negative feedback" and help clean up my description. I generally was against high-gain... Didn't like it in my FiiO portables. But with my insensitive K612, and the X7, and E5, high gain sounds to my ears more dynamic.
