Mr Router
- Apr 12, 2017
Hey im using the Creative x7 on the Xbox One. Does disabling SBX surround put the Creative X7 in Stereo Mode ? I still have the Dolby and Power LEDS Lit when I turn off the SBX
Turning off SBX turns off all the "SBX" settings - Surround, Crystalizer, Bass, Smart Volume, Dialog Plus
Any EQ will still be applicable, but any sound effects will be disabled.
Hi all, first time post here and thanks for the massive amount of infomation which is accumulated on this thread and board.
I've owned the X7 and Q701 headphones for a couple of years now and moved on from PS4 to PC gaming primarlily. I have a couple of questions and looking for advise specifically to my setup.
- Is there any quality issue when listening to music with the speaker settings in Windows 7 set to 5.1 instead of 2.0, e.g better sampling rate when running stereo output from Windows 7, or should I just leave windows settings in 5.1 and forget about it when listening to music?
- I've read the op amp reccomendations and considering an upgrade to sparkos.
- Can anyone reccomend an amp that will have better sound than the X7?
- Should I look into getting better headphones before considering upgrading the X7 or buying an additional AMP for music?
I think you would have to define what an upgrade means to you. Do you also listen to music much, or really just gaming?Thanks for the advice.
I'm thinking an amp in the price range of Schiit Jotunheim, or maybe a tube amp, however i have zero experience with those. I'm not too worried about the cost if it will be a "lifetime" investment. I came across the Atrox V2 while browsing today which seems like a good deal. I'm not going to upgrade unless it will be a step up from the X7.
Leave the X7 on High Gain at all times. The gain switch is actually a voltage limiterBeen using the X7 for a couple of months now and I like it.
For music I use direct mode but noticed that the volume steps are weird in it.
With direct mode, below 25 volume there is no sound from my TH-X00. Volume increase from 25-35 has really low change.
36 is clearly louder and 36-41 is the same volume. At 42 its again noticeably louder. (At 42 it is already as loud as I would be comfortable with)
Normal gain on Mac.
Is this normal? Without direct mode the volume is actually 100 steps as it should be. (And generally a bit louder with lower volume setting)
Just start with very low volume and work your way up. Normal Gain is pretty useless on the X7 as it's not actually a gain switch.I did think of trying it but was nervous when the X7 warns you of damaging your headphones if they are not 600 ohms.
All of my headphones are 25-32 ohms with 90-100 db efficiency so haven't tried high gain yet.
