tox1c90
- Apr 2, 2017
I did some further investigation using the udial.wav - resampling test. I think many of you know that - it's an audio file with 44.1 Khz sampling rate filled with a signal especially made to cause HEAVY distortion when going through (bad) resamplers. Actually so loud distortions that it can destroy your speakers.
So I connected some cheap speakers to the X7 line-out and tested in DSP mode with several Windows sampling rate settings. Most interesting result: When you set Windows to 44.1 Khz and play the udial.wav in DSP mode, you get extremely distorted sound. It is really screaming out of the speakers.
So with these settings Windows mixer is doing nothing and just sends the 44.1 Khz audio from the file to the X7. That you get distortion in this case means that the DSP is indeed doing some resampling.
I tested all sampling rate settings in Windows and found out that the only setting where you don't get any resampling artifacts is 48 Khz.
As a result, this means two things:
1. The resampling algorithms built into the sound mixer of Windows 10 are really really good, so that you don't even get distortions with a test file especially made to cause distortions
2. The DSP of the X7 is resampling everything to 48 Khz, and if the incoming signal is not 48 Khz, it does a worse job than Windows 10 software algorithms.
To rule out a problem with the DAC, I tested it as well in direct mode. There I got no distortion at 44.1 Khz output. That means the X7 correctly set the DAC to sampling rate of incoming audio signal, but only in direct mode!
