Digitalis
- Sep 26, 2016
Has anyone experienced and issue when having another USB audio device hooked to the computer with the X7?
I recently got some Bose Companion 5s for my birthday and ever since they also got hooked up my X7 has been acting weird. The X7 now only controls my system volume but not the volume of everything all at once like it used too. It's pretty annoying because now I have to go into the mixer menu to adjust the optical in when playing games vs just adjusting the over all system volume. Also it seems like the X7 is stuck at a certain percentage now and I cant get it too go lower or higher even when adjusting the mixer sliders. It will go higher only for any media played via the computer however, but nothing else.
I have two USB audio sources connected to my primary PC. I switch between them constantly, I haven't had any issues with hiss from my X7 - perhaps the USB ports are inherently noisy. I switch between USB audio devices in the windows 7 sound control panel, I set the primary audio device to the one I wish to use, and I have no conflicts when switching. certainly no hiss, I have a pair of very sensitive speakers connected to my X7 [ 96dB @ 1watt ] with the volume maxed out I can't hear any hiss at all. The primary device is what windows volume control will affect - any device that isn't the primary device will have to be manually adjusted. For this, I suggest using the knob on the front of the X7.
