Ok so I finally received my X7 back after a year and some change without it. The firmware update took a couple of times to fully complete itself on my MacBook Air which was a pain since I had to switch USB ports for the last 4th of the update after it claimed "the update has failed". Anyways I have a technical question but I will preface..
I currently have my Xbox One connected to the X7 through the Optical In (SPDIF). Everything is in order sound is coming into my headphones, bluetooth works and my MacBook Air plays sound fine...
My question is whenever I go into the Headphone section in the Sound Blaster X7 Control Panal on my laptop and click on "Direct Mode" or "Direct Mode (SPDIF-In)" sound cuts off from my Xbox One.
Why is that?
Also if the X7 can't play sound from the Xbox One when I have either "Direct Mode(s)" checked...what is that setting specifically made for?
Direct Mode bypasses the mixer, only USB is active in Direct Mode. Use Direct Mode S/PDIF to hear the xbox audio.
