What is the other option under Speaker output target? Is it possible to set it to headphones? Or to fixed volume?
It's almost like that option was specifically made for me and my Stax setup, lol!
As you can see, the intent is to have "speaker output" go out the powered taps on the back, the Line-out outputs, or both. Before, that was always set as "Amplifier + Line Out," or more descriptively, speaker out sends audio to both outputs. This doesn't affect the settings for when the X7 is set to "headphone out," even though they put the processed headphone surround out setting on this speakers panel of the app, lol.
Is it that people are looking to use a different, better amp with the X7? While I'm sure there are benefits, I don't understand the draw of the line out feature. After upgrading the op amps, I can't really see how much more I'd need from a headphone DAC/amp combo.
You know what... I HAVE better DACs and Amps anyway, so at some point I am going to use this feature just because, but overall I side with you.
The X7 really is a decently capable mid-fi DAC and amp, and the ability to upgrade the OpAmps is something I'd like to investigate further. For the longest time, surround processing was only available for PC, or for consoles with an external processor for about $120, and for the money the amps were always fairly weak and the DACs kinda basic (read: entry-fi fuzzy definition), and in those days we almost always had to double-amp for any headphone that wasn't designed very easy to drive and merely dream of how good surround would be with a nice DAC. Now, the X7 is more than satisfactory with almost any single ended headphone, and any upgrades would be more to suit taste rather than being underpowered. Processed Line-out and optical out is pretty niché.
That said... Providing an amping line-out and even bypassing the DAC with an optical-out had been a tradition with Creative PC products in the past, and extended the utility of those products. Don't want the perception that something was taken away, especially with Creative's TOTL product. The other aspect is that this
is Creative's TOTL product... the X7's very good, but there are technically greater products out there (but cost lots of $$$ before they're appreciably better), and it would suck if the Creative product couldn't be integrated into my best setup.
As Deadpool would say "Maximum Effort!!!"
My only gripe is the drivers. My iPad and iPhone have a hard time connecting via Bluetooth and the sound quality of USB host is way worse than Bluetooth for me, so I'm chalking that up to a driver issue, too.
Uh, my iPad and iPhone don't Bluetooth connect automatically when the X7 is on (like my BT Speaker or Creative E5 do), but every time I go into settings and tap the saved device it connects without issue. If it's harder than that for you, you could try forgetting and re-pairing your devices?
When I did an iOS update, my iPhone and iPad started intermittently not communicating/playing audio through the USB Host port, but I'm good to go after a few plug/unplugs (thought I had this problem recently but turns out I just had the USB Host volume turned down in settings). USB host sounds clearly better than Bluetooth to me.
I'm and Android guy, the USB host sounds almost the same as the main USB connection.
Same, on my iPhone and iPad. Better DAC than the iPhone's internal is clearly evident too.
WELP I just bought one second hand so I hope I don't run into any issues lol .
Welcome to de club! I think your setup looks pretty tidy too... Somebody likes their Rainbow Six, and I find it interesting you like to use a wired Mac keyboard on your windows tower. I've got one too!
My X7's volume knob has no rubbing or rough spots, just a light even resistance while turning.
