SEALBoy
- Nov 27, 2012
Define better. In what way better?
In terms of sound quality, and its handling of surround sound in games. How well does the virtual surround sound of the Z work with headphones?
In terms of DAC quality, Titanium HD has better DAC and ADC (Z/Zx have headphone amp option though). Some like SBX better, some prefer CMSS. I prefer SBX over CMSS. ZxR has better hardware than Titanium HD and it would be the most logical choice from Titanium HD.In terms of sound quality, and its handling of surround sound in games. How well does the virtual surround sound of the Z work with headphones?
Which card did you get? The mic is very bad, yes. I tried it out once, for Teamspeak, but got convinced that I should put it back into the box right away
I recall the ZXR's control panel having an option to switch between low or high impedance headphones. I know my Z doesn't have that. Maybe that will help?
PCI-E x1 can give 25 W (at least if I read it right). That should be enough. These are PCI-E native stuff, Xonars are really power inefficient with their PLX chips and all.I've had 'Do nothing' option on since forever since it messes with Skype calls and so forth. So yeah, hopefully faulty card, but I honestly still doubt it. A soundcard that doesn't use external power via a molex (like Phoebus and STX) is liable to have insufficient output power for headphones.
Ya this isn't a video card. It doesn't require external power other than the pcie lanes can provide... I believe up to 75 watts for a full height card.
I highly doubt it uses even more than 25w. You need to remember you are sending power in the milliwatts(1/1000 of a watt) to headphone drivers. Not even 1 watt. So the amp shouldn't require that much power plus whatever the card itself needs to power the DAC,opamps and the spu plus its circuits. Even if we factor the impedence it still shouldn't equal more than a few watts I'm sure just for the amp.
I think the whole extra molex to the Asus cards was to fortify the whole "cleanest power possible " theme they were going for. But not needed with modern motherboards or power supplies. I also think originally the essence stx was a PCI card(st) and maybe power draw from those connectors was limited perhaps? Meh who knows. That famous Russian site measured the stx and zxr power output and the zxr just barely measured higher if I remember correctly.
Lol any who point being I think you card is just faulty. Especially if gain settings dont make a difference. Like one of the other members suggested do you hear the relay click when ur PC boots into windows? A bad driver install could impede the amp from engaging or something along those lines.
My DT 770 250 ohm is definitely not easy to drive yet on the 32-300 ohm gain setting I have to have it on 25-30 % volume or it'll blow my ears lol.
A member on the overckock.net forums had the same problem as you with the zxr. So not the first time. Before you return it try to clean yours drivers up or an os install. You never know.
