razorpakk
- Jan 3, 2015
Oh I don't mind losing the SBX features, I've never used them!
I recently contact Creative for a problem of these products about the amplification gain setting not present.
And Creative confirm it ! In the Z and ZX is not possible set the amplification gain for the headphone, then the card give always permanent 600 ohm !!! and Creative recommends to decreasing the volume from Windows.
The questions are :
1 ) This situation still can give some problems so ?
2 ) If i plug a traditional headphone with 30-32 ohm the sound can be distorted or tampered than its original sound ?
[COLOR=333333]The questions are :[/COLOR]
[COLOR=333333]
[/COLOR][COLOR=333333][COLOR=FF0000]1 )[/COLOR][/COLOR][COLOR=333333] This situation still can give some problems so ? [/COLOR][COLOR=333333]
[/COLOR][COLOR=333333][COLOR=FF0000]2 )[/COLOR] If i plug a traditional headphone with 30-32 ohm the sound can be [/COLOR]distorted or tampered than its original sound ?
The 600 ohm setting means the GAIN is always the same (pretty high gain), not that the OUTPUT IMPEDANCE is that high. I think you mixed together those specifications by mistake.
High gain means the volume will be quite loud, I have my windows set for 24-bit/196kHz audio and then the volume dialed down to like 20-28% and it sounds fine.
Now, the Z and Zx have like 10 or 14 ohms output impedance... That's completely separate from what you asked creative. That output impedance makes bass levels higher in some headphones, possibly high enough to cause distortion, but not all headphones react the same. You should hear no effect if the headphones have a flat/mostly flat impedance response curve (see headroom or InnerFidelity for charts) or if your headphone has about 8x the impedance (~80 ohms or higher, close to 80 ohms will have minimal effect). Sometimes the effect is mild and people like it.
Creative's newer top-of-the-line X7 has about a 2 Ohm output impedance, which is great for almost any headphone without dampening so much that the headphone sounds thin.
Z and Zx result have 22ohm in output
not 10-14
Okay, so substitute that info, and pretty much all the rest of my post still stands. Thanks for the accurate info.
this means that SBZ is a false good sound card![]()
-_-
I mean, I wouldn't use an SBZ with an IEM, but it sounded great with my AKG's, "problem" solved. Lower output impedance on the sound card would be nice, but I think it's more relevant to find out if a headphone has an uneven impedance response... Saying a stereotype like "the SBZ is a bad sound card" is like a stereotype saying "French people smell bad," it's just ignorant thinking and not true in every case.
Impedance
The sum of both resistive and reactive impeding forces of a load. Headphone impedance commonly changes with frequency, and would become somewhat inductive or capacitive at different frequencies.
I can only speak from my own experience with a Zx and AKG 612 Pro's.
