I tried to plug the USb cable during playing and it is now in a continous loop of database update and can't power it down. Now i know that you can't charge while your listening to it.
Suggestions .
Suggestions .
Suggestions .
I was using the player (as playing music) connected to headphones and then the battery was getting low and so I plugged the player by usb cable that was connected to my computer.
The reboot process fixed the problem and now I know to use the a straight USB charger not the computer when listening to music.
Still ove this player especailly with new amp burning in from RSA Blackbird SR-71B on a blannced cable. Great soundstage and the HE-400I sound even better.
Thanks for the help guys.
plenue m2 can't turn on! i try with hold + and - bottom for 2m but nothing happens
Someone idea?, only led blue
If the screen is turned off while the product is turned on, the LED will blink blue. Try to connect it to the computer, since even trying to reset, nothing happened.
if i connect my pm2 on computer the led color is '' blue sky '', the led never blink stay turn on. 4 hrs and nothing happens
Does the computer recognize M2? If so, sometimes it's worth trying to format the internal memory.
