Vitor Valeri
- May 8, 2011
Topic created for the player Cowon Plenue D users to report any problems they are having with the device.
Problems solved:
1 - Noise During the exchange of track
I'm having a problem with Plenue D. The songs of the internal memory of the player during the exchange of track to another track are showing noise (very low), but this only happens when the screen is off. The noise is much weaker in the SD card , however it is still . It has a solution for this problem?
Firmware V. 1.14 fixed the problem
Problems to be solved:
1 - More skins options
Add more skins options for Plenue D. I would be very happy if I had more options. And I wish you had (if possible) any skin that owned a VU Meter (I attached a picture illustrating).
2 - Maximum number of files it's too small
After I bought a 128GB micro SD card for my Plenue D I noticed that the file limit is too small. Increase this limit in the next firmware
3 -Limit for reading micro SD cards up to 128GB
Many users are having trouble using micro SD card with 200GB capacity. People can copy the files to the card, they appear on the PC, but do not play when the Plenue D is being used.
Problems solved:
