orys
- Nov 23, 2008
Will this take 400gb and 512gb sdxc cards?
I'm using a 400GB card in mine - works fine although the database update slows the boot timeWill this take 400gb and 512gb sdxc cards?
SanDisk Ultra - no stutterWhich brand model?
Is it playing flawlessly or does it stutter at times?
Should add that I'm using 289GB of the card as 1778 folders with 36,678 files and all music is on the SD card.SanDisk Ultra - no stutter
Great job Dr. frankensteinThe Plenue L is now not the only Plenue with a 4.4mm Pentaconn
Plenue 2 4.4mm mod
Lovely! So the braces for 4.4 and 3.5 are the same on board ?The Plenue L is now not the only Plenue with a 4.4mm Pentaconn
Plenue 2 4.4mm mod
Did you have to drill to enlarge the bore ? Or you slide right throughIn case your wondering.
