Originally Posted by Rip N' Burn /img/forum/go_quote.gif
I've installed D2+ firmware on my original D2 so I can take advantage of BBE+. I also have rockbox installed as well which is a nice bonus. You can also replace the battery very easily. I don't think it is possible with the clip+.
Replaceable battery? Wow. I didn't know about that.
anadin, Rip N' Burn, you both have emphasized Rockbox, but what really does it add to the Cowon firmware? (I'm not challenging it's usefulness, I'm just curious.) Also, on the Rockbox website, it says that the D2 port is unstable; have you experienced any sorts of problems with it?
limathy, I'm in the same situation as you, considering the possibility of getting the D2, leaving the extra cash toward some HD 25-1 (possibly!). However, the thing that's stopping me is how I'll probably feel about the device in two years. With the S9, I think it's safe to say that Apple will have caught up by two years in terms of SQ and screen, but I doubt the codec support will ever really be there. Also, I don't care too much for the looks of either the D2+ or S9, but given the choice, I'd go with the S9.
On the other hand, swappable SDs are going to get really cheap in the future, allowing you to pretty much buy a new D2+'s worth of memory for <50$ in a few years.
I think it'll come down (for me at least), to what types of deals are available in the coming weeks of thanksgiving/holiday season, and make my decision off of it.
(I'll be pissed if I buy a S9/[or even a D2+ for that matter], and then Cowon releases a S9 with swappable memory a few months later.)
