Comply "P" series and Shure Olives for Fischer Audio DBA-02
May 30, 2011 at 3:47 AM Thread Starter Post #1 of 11
Rainman26
Is the comply P series compatible for DBA-02? What about the shure olives? Complyfoam do only show t-100 for fischer audio  t-100 is also compatible with shures. Thanks!
Jun 28, 2011 at 5:45 PM Post #2 of 11
Technically the P-Series will fit on the sound port of the DBA-02 because it's a 100-sized core, but the sound port is too short. Our engineers didn't approve it with the P-Series for a number of reasons, one of them being the P-Series foam fitting the ear canal and spilling over the sound port, which diminished the sound quality.
Jun 28, 2011 at 8:26 PM Post #3 of 11
I know there is a fellow Headfier here (Shane maybe) that uses those on his DBA-02, and cuts them short. He does not use anyhting else and swears by them
Jun 29, 2011 at 1:49 AM Post #4 of 11
You should consider the Ts series too. It is easier to fit and slightly better sounding than the normal T series.
Jun 29, 2011 at 2:21 AM Post #5 of 11
Yes. That would be me, and 100% correct.
Trimmed flat to the black plastic core. Bliss.
Jun 29, 2011 at 6:46 PM Post #6 of 11
Yeah I just ordered some Ts myself. I'm looking forward to giving them a shot.
Jun 30, 2011 at 1:53 AM Post #7 of 11
Some shots with the brand new B2's (virtually identical to the DBA's).
P-series 'Standard' size. Trimmed.
Jul 2, 2011 at 7:24 AM Post #8 of 11
Nice trim for your complys, apparently, my canal on my left canal is deep, and trimming is not for me. Thanks for the pictures though. I appreciate your effort.
Jul 2, 2011 at 7:25 AM Post #9 of 11
Thanks comply for reasoning it out. I just ordered P-series and try to trim it.
Jul 5, 2011 at 12:09 PM Post #11 of 11
... What about the shure olives? ... Thanks!
Shure olives fit the DBA-02 nozzles. They are quite snug, and need considerable patience when removing.
