bluntman
- Apr 11, 2010
I just purchased these today, and was feeling doubt because the super tips were no way in hell going to work out for me, and let me just inform you that these Foam tips not only increase the sound stage of the Coppers, but they bring out all the detail, bass and entirety the Coppers are equipped with.
I have finally apprehended the reason why these Coppers were all glorified and destined to be given a superb score in reviews by all and professionals.
I went from,
ehhhh,
to,
WOW, I can't believe my ****ing ears!
Not only do these foam tips keep the noise isolation to 100%, but they keep these heavy babies locked inside of your ears...there is no way in hell they can bother you or feel like they're about to fall out as they have to me with the stock tips.
My ears are bleeding for more music with these babies.
THANK YOU COMPLY FOAM TIPS!
http://www.bhphotovideo.com/c/product/642769-REG/Hearing_Components_17_40200_00_Comply_T_400_Foam_Tips.html
http://www.amazon.com/Comply-T-400-Foam-Tips-Pair/dp/B001DXGBII/ref=sr_1_1?ie=UTF8&s=electronics&qid=1280508416&sr=8-1
I went from,
ehhhh,
to,
