Dubstep Girl
awesome review! short and simple.
That is what i'm wondering. Well I have the audinst, I just want to know whether the magni will do a better job than the built in amp of the audinst.
I hate to say it again but there downfalls (bass distortion) with the ODAC and O2 when using high impedance phones (HD600) on high gains. In response to my question, John from JDS Labs said: "This occurs with O2 when using a strong source/DAC with some headphones. You simply need a higher voltage AC adapter to use high gain. More information can be found on the instructions guide." On the other hand, you can't ever make the Magni portable!
I've not heard of this problem before. Having just got teh ODAC, I notice that the strength of the output makes cruising up to 12 O'Clock or more quite loud. At stock 2.5x gain, you can clip on battery (I think), but not on AC. What gain/volume settings are you talking about? It would seem like you would have to be really cranking the crap out of the phones. Just curious.
Nope. Just your normal 9-10 pm. I really thought it was the headphones falling apart (HD650), but it was the ODAC/O2 combo. I felt better when JDS Labs confirmed it was a known issue. For me, I felt the HD650 needs the dynamics of high gain; low gain is fine, and I was perfectly happy with low gain with the HD600. But if you use an Ipod line out as source, you don't have the issue becaues of output impedance of ODAC... or something like that.
Something about the stack and aesthetics that makes it more worthwhile to me. The ODAC is so discreet, and the O2 has a mess of cables in the front. I'd rather hide those away, while the Schiit stack is something I'm proud to have displayed.
Hello I'm a complete newbie to this audio system area..
I decided for a change and looked toward more dedicated sound setup for my PC
I will be gaming a lot so I won't be getting a DAC, but getting a sound card(Ti-HD)...
I have firmly decided that I will be getting Q701 and Ti-HD, but still haven't decided on an amp.
Magni is quite new so I haven't seen any specific indepth review other than this thread.
To the question.... Is O2 better or Magni better to drive the Q701s?
I appreciate your answers! And I apologize to drop a question on a review...
