Ren19
- Nov 8, 2012
If the "Objective Combo" and "The Schiit Stack" would be the same price, wich one should i get for a pair of headphones like the Q701?
Quote:If the "Objective Combo" and "The Schiit Stack" would be the same price, wich one should i get for a pair of headphones like the Q701?
Objective ofcourse. I doubt any amp has been tested as thoroughly as the O2.
The O2 design has been tested and measured thoroughly and blind a/b puts them close enough together. So unless you like the ergonomics of the Schiit stuff much better I'd go O2/ODAC.
schiit seems to be more secretive in keeping their designs known, patent issues maybe, with the praise that O2/ODAC is being given as a good design, its like you're all discrediting schiit's engineers, whom I think are quite brilliant themselves,
but O2/ODAC is open source, seems like the designer wanted it to be known how to make a good amp
Stop brown-nosing. There's nothing special about the additional measurements in the Objective 2's blog. I'm sure you'll find very minimal differences between all these measurements when comparing the O2 and Magni-- and any of the more prominent differences would be below the threshold of realistic listening levels (do we all really need to know that an amp has a -116db noise floor at half volume) I'm a very measurement first type of guy, but at the end of the day I still rather go off subjective impressions of equipment from people whom I trust rather than looking at graphs all day.
Next I expect you to say that the O2 sounds the same as 1000 dollar amps in blind a/b comparisons.
And not just tested by the designer, but by others potentially with a bone to pick. These others haven't found results that disagree with what's out there. Also Tyll at IF to some degree. So it is better-known, for whatever that is worth. You can check the schematic too.
Personally I'd like to have more information available about everything, but I don't think they're all out there to cater to me.
It's not at all a fair comparison from the designers' point of view in terms of information available and transparency because Schiit needs to make money and stuff, keep things under wraps. No company wants to disclose too much to the customers and competitors. From the consumer's point of view, depends on your priorities.
Then you're just saying the O2/ODAC are better than everything else because of the numbers. I'm not saying that $5000 amps/dacs are necessarily better than the O2/ODAC. I'm just saying that better things exist.
