Planar_head
- Jul 3, 2008
Oo, that's interesting. I just recently got a Aeropress and feel that I finally got the technique down for a good hot cup. Might be time to switch it up and go cold-brew.
I'm just back from visiting the folks over Christmas, and coming home to the kind of coffee that you get from the Aeropress is wonderful.
My sister has one of those capsule machines and it just isn't as good...
I have a higher end tasamo. No comparison to my aeropress. Although the tasamo is very good for what it is. The bar code system really does put kuregg to shame, it can foam, and a just pressure, and water depending on what the code tells it to do. But the coffee sits in the packs pre ground for a long time, ends up slightly plasticy and fake tasting. Despite being a semi decent brand. Then all the waste from the packs.
Can't even touch even my simple aeropress with fresh ground to serve, local roasted coffee. Just uses a simple tiny paper filter (you can get reusable metal ones)
Meanwhile, I am about to try roasting green coffee beans for the first time ever. Okay, dry-frying them, rather than roasting. Fingers crossed!
Second attempt at coffee roasting/frying. I started on medium heat, then raised the temperature in two steps 'til the husks started cracking.
I also used a very thick-bottomed saucepan, to even out the heat distribution and stirred the beans more than I did last time. A much more even-looking result.
This batch will get its first grind for tomorrow morning's cuppa - I will report back.
This is probably a dumb question but, do you have to turn them? If so, how do you do that?
I've always liked the french press the best but also use poor over for the mornings when I don't want to deal with the press method.
I need to try some of these other ways to compare.
