skeptic
Haloxt - thanks for the response. I noticed the same language in the cplay online documentation, but I still don't comprehend how a software volume control is consistent with the notion of passing bit perfect data.
Here's my reasoning - if it is flawed, please show me the light!
My DAC provides an analog output from the "bit-perfect" data it receives from both WinAmp ASIO and Foobar ASIO/KS that is at the exact same volume.
Cplay is supposed to be bit-perfect, but it can play at variable volumes....and the default results in a quieter analog output from my DAC than either of the other programs.
The DAC only receives 1's and 0's from the computer - so in order for the cplay output to sound different from the Winamp/Foobar output, I have to conclude that cplay is actually passing a different number/sequence of 1's and 0's.
Unless volume is a factor that is somehow excluded from the notion of a bit-perfect data stream, I have to conclude that Cplay (and any other software with a volume control) is corrupting the digital data in some way shape or form in order to allow for variable volume.
Am I way off here?
Originally Posted by haloxt /img/forum/go_quote.gif Volume control can be done by the media player, not just kmixer, I used to control volume with foobar+asio. Here's the description of the volume control on cplay: "Offers high quality 64 bit double precision digital volume control (in 0.5db steps). This can be bypassed." Cplay alone (with cmp it gets even kookier) I also could only use single files or else cuesheet, and it makes me close the program every time before double-clicking on a new file to play, but I could just be doing things wrong |
Am I way off here?
