NeilR
- Dec 2, 2005
Yup, switch 'em.
Edit: any time you hand wire a pot, it's a good idea to measure resistance between a middle pin and outer pin to see where the "zero point" is when the pot is at minimum volume. The outer pin that reads (almost) zero ohms to the middle pin goes to ground. The other pin goes to your input jack and that should read the full pot resistance to the middle pin at minimum volume. After screwing it up a couple times you'll get the hang of it.
Originally Posted by Eisenhower It works great, one last question, My alps pot/switch is backwards, IE when I turn it on it starts out at the loudest setting, then tapers down. Did I just solder my wipers in backwards? should I just switch them? |
Yup, switch 'em.
