thedoctor
- Mar 31, 2006
been so long since i've built my CMOY, but isn't you supposed not to hear anything without the battery plugged in?
and do you have a multimeter with you? do check for DC offset. if you're using the same Opamp as before, then most probably it's already dead when plugged in the wrong way.
Originally Posted by Eisenhower I fixed the tle and mounted the opamp correctly, nothing gets hot anymore But, I tried hooking up a pcdp and a pair of cheapo headphones like tangents guide said and when the battery isnt hooked up, it sounds like just a pcdp, but when the battery is hooked up, the signal gets very faint and crackley. |
