Hemlocke
I had not really considered any HFM stuff, but I'm only familiar with their open-back planars (Last two versions of HE-400i). I actually keep Dynamat around the house.Also consider the Hifiman HE-R9 with a decently in-depth review:
https://store.hifiman.com/index.php/he-r9.html
https://www.techpowerup.com/review/hifiman-he-r9-closed-back-headphones/
If you feel like the bass is too strong and would be willing to put dynamat in the ear cups to reduce vibration/distortion:
https://www.amazon.com/Dynamat-10425-Self-Adhesive-Deadener-Xtreme/dp/B00020CAVA/
https://www.amazon.com/Dynamat-13100-Dynatape-1-1-30ft/dp/B002WP362U/?th=1
If you want to get a HE-R9 and make it wireless, then you should just also get a free Hifiman Deva Pro as well:
https://store.hifiman.com/index.php/deva-pro.html
Lastly, to add more long-term comfort to any Hifiman headband:
https://www.amazon.com/Cooling-Gel-Headband-Protector-Compatible-Headphones/dp/B094Y67C21/
I loathe the new HFM headbands, and I have a large-ish head, which may be a problem for me. I'll take a look. Thanks.
