- Feb 11, 2008
Will any micro to micro work for connecting this to my s6 edge? Got the mojo but not the cable
No, it must be an OTG cable (as opposed to a standard data or charging cable)
Look in Post #3 for more info
So all of a sudden, this micro usb otg cable to connect the mojo to my s6 edge is like finding the holy grail...
Did you look in Post #3, as I suggested?
It contains a link to this:
Any particular OTG cable recommendations for connecting the Mojo to a Note 4 phone? Thank you.
http://www.custom-cable.co.uk/vertere-micro-usb-to-usb-b-usb-otg-on-the-go-cable.html
Micro to Micro option
Alternatively, if you need something cheaper, then, as bavinck mentioned, you can often find them on eBay (sometimes you may need to get one from a Chinese seller, sometimes a UK / USA seller)
Here's one: http://www.ebay.co.uk/itm/10cm-Right-Angle-to-Left-Angle-Micro-USB-Host-OTG-Cable-4-DAC-Digital-Amplifier-/301669713346?hash=item463cea85c2:g:m3wAAOSwZjJVAUdu
