Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
923 924 925 926 927 928 929 930 931 932
934 935 936 937 938 939 940 941 942 943
  1. twiceboss
    So you just got yours right? How it compares to the others that u own?
  2. noobandroid
    i sold all my other audio hardware just to get a mojo and use it both home and mobile
  3. x RELIC x Contributor
    On the measurement side you need to buy a DAC in the thousands of dollars to beat the Mojo.
  4. twiceboss
    Wow, so much respect on Mojo, really looking forward BRUH!
  5. bavinck
    I feel like we are in a frat house on Friday night, drinking and talking Mojo.... Oye.
    Rob? Rob? It would be really nice for you to teach us something right about now.... Please? With a cherry on top (as my daughter would say)?
  6. UNOE
    Was that test just charging? Have you tested while playing what the draw is ?
  7. rkt31
    @twiceboss, there can be ways where you can use mojo for desktop use, like you can put mojo in a wooden fixed by double sided tape or by blue tack or by using some rubber bands etc . a small portable can be made to use in a bigger set up but vice versa is not true. mojo that way is so much versatile. mojo will be benefitted greatly if fed directly to a power amplifier .
  8. rkt31
    wooden box
  9. Rob Watts
    Yes I have been promising to start my blog for past couple of weeks. Something coming soon - the first article is going to be about listening tests.
    You may say why bother, if it sounds better its better isn't it?
    But its actually much more difficult as it first seems, as it is very easy to enjoy the sound of distortion - so objectively assessing sound quality is not an easy process. It also becomes a nightmare when many variables are changing at the same time (some things better, some things worse). Then there is the factor of eliminating system optimization (quick example, adding a false brightness to a soft sounding system), then you can see that making engineering decisions via listening tests is not as simple as one might think.
    Rob
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
    onsionsi and masterpfa like this.
  10. msp
    Hallo, want to mount a new plug on my Fostex, and I have ordered a Viablue T6s (the normal size)  But will it be to large--is there anyone that have tried this... My concern is that it will lift the mojo from the table
    Hope on some input--if it does I will need to cancel my order.
    Kind regards Morten
  11. twiceboss
    Haha lol. Just wondering if there are any desktop system that can beat it in that price range since portable sometimes cost higher bcus of battery and else.
  12. music4mhell
    yes it can, go for Schiit YGGDRASIL @ $2,299, i don't know any desktop DAC can beat at this price range, not even at $1000 range.
    I use Mojo as desktop Dac with my Genelecs everyday. By the way i choose Mojo over Audiolab MDAC, and Arcam irDac and some other desktop Dacs.
  13. noobandroid
    anyone can chime in on possible damages to mojo by charging with power ripple sound consistently?
  14. Rob Watts
    It has been designed to accommodate noisy PSU's both from a safety and sound quality POV.
    If it has too much ripple, or the charging voltage falls by too much, then the charge protect circuit will trigger, and the charging LED (battery light is white) will flash. So as long as the battery LED does not flash white it is fine.
    Rob
    onsionsi likes this.
  15. rkt31
    I doubt schiit yggdrasil betters mojo for sq. mojo IMHO is better than Hugo too in some areas depending upon the preference while maintaining supreme level of details. yggdrasil has to use a preamp which gives the advantage to mojo. even comparing direct output of yggdrasil to headphone or even with an amp mojo should be better.
