Superdrag81
Just purchased/pre-ordered on moon audio...hopefully i got into their second order before it sold out!
I'll just leave this here.
http://www.head-fi.org/products/chord-mojo/reviews/14291
I ended up going out last night with an iPhone 6plus, a blackberry, mojo AND Fiio x5. Weighed a ton!
Since we're on the topic of sources: Some new smartphones have native support for DSD. Will this be an advantage if used for transport with the MOJO? I'm guessing a third party app will have to be installed anyway, am I right?
Sound-wise, a "good" transport would have the lowest possible levels of jitter and an in-spec implementation of the specific optical/electrical interface. So, clock quality would be a factor (to a certain extent), as would be the implementation of the physical layer being used. Depending on the DAC implementation, the source clock/jitter importance would be more or less important (not using the clock from the incoming data fixes one source of jitter issues).
For example, I find it difficult to believe that any of the AK players from the original AK100 up to the latest AK380 sound any different via their optical outputs into a Mojo.
Beyond that it's all about size, capacity, UX and battery life in whatever balance is important to you.
My 0.01 GBP at least ...
So you think the AKs sound the same via USB and optical, but superior to non-hifi transports, if I understand this correctly.
Thanks, this is helpful.
How much does this affect sound in the end, in your opinion? I'm new here and I don't know what consensus on level of audiophile delusion we're labouring under here is, so it's hard to interpret what exactly impressions in a review translates to. Do you think, for example, that 10 random people from this thread could in a blind A/B test identify with any degree of consistency if the same track is fed to the MOJO from an AK380 or an android phone in airplane mode?
Help
The iPhone Camera Connection still appears to only work for the iPad, not the iPhone 6S - anyone with similar experience?
