Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Mar 3, 2016 at 8:51 PM Post #12,317 of 42,765
used mojo is so hard to get, sad
Mar 3, 2016 at 9:05 PM Post #12,318 of 42,765
Are there any photos of the 'smooth' OEM Mojo case?
Prototypes from waaaay back in this thread, re-posted a couple times. These are not guaranteed to be final production. Other than this, nothing.
And the pics you posted of the Dignus case for others to see a better sample.
Mar 3, 2016 at 9:11 PM Post #12,319 of 42,765
that dignus case has a hook chain which is nice
Mar 3, 2016 at 9:29 PM Post #12,321 of 42,765
Looks like the OEM case might add a bit of bulk. Not ideal if you want to stack the Mojo with that on... I haven't seen the Dignis one but if it is anything like their Onkyo DP-X1 case that I've got (and that is way better than Onkyo's own), I'm a happy camper. Stacking the two with the bicycle rubber should be easy.
Mar 3, 2016 at 9:47 PM Post #12,323 of 42,765
In reading the 3rd post and the FAQ section it is still a bit confusing on how to hook up to the iPhone 6.
"If your iDevice can use a Camera Connection Kit (CCK) then you'll need to get the CCK cable from apple which has a USB A socket on one end and use a USB A to micro B cable. You cannot use old scroll-wheel type iPods."
Is this correct?
http://www.amazon.com/gp/product/B00VU2OID2/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
and then the next one?
http://www.amazon.com/gp/product/B00XVU4IPO?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A2KUZVNQ9LP7N9​
I am just looking for the 2 basic connectors to iPhone 6; not anything terribly expensive.  Are these correct?  Amazon is helpful in using links to point out the proper examples.
Thanks.
Those won't work. You need the Apple Lightning to USB Camera Adaptor in order to get the digital audio out from the iDevice. There is an MFI apple chip in the cable that allows digital audio to the external device. This is a two cable setup and rather bulky because you need a USB to micro USB cable plugged in to the camera adaptor from to the Mojo.
You can find it at the Apple store:
http://www.apple.com/shop/product/MD821AM/A/lightning-to-usb-camera-adapter
For a one cable solution you can grab a cable from Lavricables that has the MFI chip built in to the lightning to micro USB cables he builds. Feedback has been positive about the Lavricables cable with the Mojo and IOS devices.
You can find it here:
http://www.ebay.ca/itm/Pure-Solid-Silver-Lightning-to-Chord-Hugo-Mojo-interconnect-cable-Iphone-4-5-6-/172046678763
Edit: The first cable you linked might work, but it's from China and these have been touch and go. Why not get the official one for $10 more.
Edit2: This is a pic of what you need to hook up the Mojo with the Apple camera USB to Lightning adaptor.
You can see it's a no go with the 30 pin adaptor for the iPod Classic. The OS won't support it.
Mar 3, 2016 at 11:04 PM Post #12,326 of 42,765
  I received my Fiio -> Mojo coax connector from Dyson Audio yesterday. Couldn't be happier with the purchase. Well made cable, and at first listen, I think the coax connection actually sounds even better than the USB output from my MBP.
I believe that I am the first person ask Dyson to make a customized cable with Right angle but I haven't received my cable yet. Dyson made cable and shipped amazing fast but USPS is the most stupid international shipping service I've ever used. My cable still travels around US after 10 days :frowning2:
Mar 3, 2016 at 11:09 PM Post #12,327 of 42,765
install foobar asio component. select chord asio driver as output in foobar. this is the best and most direct method. it bypasses all windows processes. install mojo driver first.
wasapi is alternative, use under event mode
Mar 4, 2016 at 12:00 AM Post #12,328 of 42,765
Will that cable work with the ibasso dx50? Ive been wanting to get a right angled cable to stack the mojo and dx50.
Mar 4, 2016 at 12:48 AM Post #12,330 of 42,765
Still looking for a short optical cable *sysconcep doesn't have the style I want* alo audio was of horrible quality, I wonder how come short cables are so hard to come by... Do you guys think more manufacturers will end up making more?
Hey Naive, have you tried reaching out to Sysconcept to see if they could custom their cable to a right angle?
Actually, they do: http://www.sys-concept.com/U-toslink_miniplug.html
But aren't their low profile cables even better in terms of portability when compared to a "typical" Toslink to mini jack optical cable?
