Carl6868
- Dec 10, 2011
According to given picture the samsung adaptor delivers 2A current which is more than mojo's recomminded current rating (1A). I think that may be the reason.
So try to charge your mojo using 1A charging adaptor (optimum one is apple iphone charger which deliver 1A).
If still issue exists , as per my understanding you have to RMA.
Next time never use any kind of adaptor which delivers more than 1A. Seems that this is a good lesson!!!
That's not correct, the mojo or any other piece of equipment will only draw the current that it needs to charge, there is no disadvantage having a higher current charger than needed and it is better to have more current available rather then not enough !
Also the 1amp iPhone charger you recommend isn't ideal as it is the bare minimum needed and I believe a number of the issues in this thread about mojo batteries discharging too quickly are due to inadequate chargers !
Edit: too slow
