SearchOfSub
- Aug 28, 2013
Cost effective and best thing are opposing conditions. Moon Audio has both coax and Toslink cables that would meet your needs in the $75 to $100 price range. They are 6 inch cables with straight plugs while your Fiio cable is about 4 inches with right angle plugs. Your cable was designed for an analog signal, but could work since it is a sheathed cable but not a 75 ohm coax cable.
Not sure what problem you are trying to fix, but replacing your $14 cable with something almost as short will cost a lot more. If interested, contact Moon Audio (forum sponsor) and ask them if he can put right angle connectors on the coax cable.
I'd skip any adapters entirely if I were you. I wouldn't want any signal degration on the Mojo and any components added in the chain will degrade the sound most likely. You can call cable companies and they would make one for you in custom legnths. Blue Moons, Kimbre, Audioquest, Audience are a few cable companies. Although besides blue moons are cable companies geared more towards stereo speaker setups but you never know. I'd give blue moons a call first and get a quote.
