- Oct 14, 2013
I tried Onkyo app with mojo. It only stutter when up converting. The bad thing is that up converting is standard, just go into setting and don't up convert it, just turn the option off
George - As far as I know there's no packet verification when transmitting audio signals from a transport to a DAC like there is with traditional digital data transmission. It's a live, one way stream - there's no error correction or resend requests or such. That's one reason why sources and cables do make a difference in this type of USB use in audio application as compared to TCP/IP, etc. Happy to be corrected but that's how I've always understood it. Cheers
I am considering the Mojo for use mainly as a USB DAC connected to my laptop. How does the battery behave when fully charged and the device is working at the same time that the charging USB is connected? Does it keep draining the battery and charging it at the same time or does it bypass the battery and function from the power received via USB?
Also, what life expectancy would this battery have? Would it be easily replaceable by the user?
It won
It won't by pass, mojo takes power only from Battery.
According to John Frank, Life expectancy of Battery in Mojo is around 10/15 Years.
And yes, it's easily replaceable.
I'm using ak100ii to mojo and found out that it can only play up to 24 / 96 using toslink. Since I have a generic toslink (1.5m) that is too long, I decided to shorten it using my very limited skill and try to see if it will work.
And to my surprise, not only did it work, but now it plays 24/192 and most surprisingly, it now plays up to DSD 5.6MHz!!!
DSD 5.6MHz (note the color of the power button)
DSD 2.8MHz
24/192kHz
I'm just used a cheap 'generic' toslink cable
Of course the ak100ii uses DoP but to be able to play higher than 24/92 over toslink... is beyond my expectations for a spontaneous DIY cable project
Sorry but DSD is white. The Mojo is displaying 176kHz PCM (cyan colour) converted from DSD to PCM by the AK100ii.
Still, very impressive for DIY on the optical cable! Congrats!
Edit: Believe me, nothing wrong with PCM on the Mojo!
Stamina mode is disabled.
is there any difference in SQ between via cck and via Taobao lightning-micro-USB cable? im still waiting for that cable from taobao too.
Has anyone had the chance to compare mojo to vali 2? Are they on equal ground?
