Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
192 193 194 195 196 197 198 199 200 201
203 204 205 206 207 208 209 210 211 212
  1. AndrewH13
    The iBasso lead connects to Hugo but needs a Phono/3.5 adapter fitted to connect to Mojo.
  2. almoskosz
    Hi guys, so I'm looking for an amp/dac and found this little baby that just happens to float my boat :D
    My only concern is that it has (based on what i've read) an output power of 720mW at 8ohm, which is not the best I've seen (correct me if I'm wrong), and I'd use an orthodynamic (Hifiman He400i) with it, which are told to require a lot of currency to sound good.
    Any thoughts on this? Or has anyone tried it with such headphones?
    Thanks for the kind help!
    Best, almoskosz
    [​IMG]
  3. pitchblack
    Mojo does not play 176 & 192 kHz Material via Toslink from AK240. Equal or less than 96 kHz are no problem. LG G4 OTG with 176 & 192 kHz no problem on the Mojo.
    Btw the AK240 plays everything till 192 kHz with Toslink on the iFi iDAC micro without an issue.
    Only difference between the iFi and Mojo connection is the optical cable (I don't have yet a short Mini-Optical to Toslink cable).
    The stuck buttons are gone after moving the balls a little bit.
    send with LG G4
  4. gavinfabl
    Tricky one to have all that you want.
    LG Flex 2 - subsequent software updates have improved the heat issue, but not totally removed it. If it gets warm/hot battery drops faster. Its ok but personally I would not buy. I would get a phone with an 808 processor eg LG G4 isnt much more than the Flex 2..
  5. pitchblack
    not the cable....hmm very weird
    send with LG G4
  6. x RELIC x Contributor
    From my experience with the Mojo and LCD-2 (pre-fazor) you'll be more than ok with the HE-400i.
  7. Mython Contributor
    Did you see Duncan's remarks, in regard to the AK120s?
    OK, so yours is a 240, not a 120, but it might still be worth trying a shorter optical cable (Sysconcept or similar), and see what happens....
  8. mscott58
    192 works with my AK100 and the Sys Connect cable.
  9. almoskosz
    Thanks!
  10. dpm78
  11. mscott58
  12. pitchblack
    @Duncan, @Mython, @mscott58
    Thanks, I will try it as soon as possible
  13. cattlethief
    I also had a few problems with 3-1metre length cables ,wouldnt play above 24/96 with mojo but were fine with my othere dacs,sysconcept cabled worked just fine.
  14. headwhacker
    Sorry I forgot you need a 3.5mm to 3.5mm for Hugo. Ibaso's cable has the coax connector at one end
  15. fumoffuXx
    i made one for the Mojo to iBasso, get a 75ohm  coax cable and 2 trs 3.5mm jacks. short both Left and Right together for data in and then ground for the shielding.
