- Nov 11, 2004
Thanks much Bixby:
Hope you don't mind throwing me another bone. I'm getting excited that I seem to be getting a handle on all of this seemingly elementary knowledge; seeing light at the other end of the Mojo tunnel for home based listening.
You suggest acquiring an inexpensive USB cable with a ferrite already attached with an additional one at the other end.
1.Would you suggest getting them as close to the end of the cable as possible as Ike suggests for better RF reduction?
2. If this is the case and the ones with fixed ferrites are not really butt up against the ends of the cable, would it be better to purchase a ferriteless cable and then separates to apply to the cable ends?
3. What do you think of Ike's idea of large ferrite + small? Would there be some science behind this?
4. To this end, do you know of cable companies whose USB micro ends have proven to fit nice and snug into the Mojo for I understand that some of the companies tolerances are not kind to the Mojo USB.
Finally on another note, can you suggest a couple of 3.5 to RCA cable brands and models to go into my integrated from the Mojo? What would be the minimum quality before I would start getting into diminished returns? Do not want to cheap out, but at the same time do not want to pay for the indiscernible.
Thanks so much Bixby. Really appreciate you time.
1. yes
2. no, ferrites in the cable are ok. I found Monoprice 24/28 with ferrite on one end in a .5 meter to work well. An additional ferrite is helpful. Note that in some cases some aluminum foil around the usb connector on the computer end can provide some extra shielding if your port is right next to the power like on many laptops. Emi can affect since the connector is not shielded fully.
3. Large ferrites or small does not make a difference. Ferrites work by increasing the impedance near the wire at a particular freq range based on mix formula. To increase the impedance even more you do more turns of wire in the ferrite typically using a split ferrite.
4. The micro connector is what it is. And the Monoprice one works as well as many for fit. I have no problems. Just be aware nearly 60% of USB cables in one test failed to meet usb specs and variability has no cost bounds. I managed to have good luck with the ones I have from them.
Yes, I can suggest a very good 3.5 to rca cable made by Audio Sensibilities. .7 meters is about $90 Do not be tempted to buy an "audiophile adapter", they suck and even your $400-$500 rca cables will not bring out the best as compared to a proper 3.5 to rca cable. Trust me I spent a weekend working this out, haha.
