- Feb 11, 2008
Rob has discussed the (relative**) immunity of optical connections to RF, and the influences of undesirable RF on analogue circuitry. A USB cable may well be carrying a digital signal, but it can also, inadvertently, carry RF noise which may manage to influence analogue components on the PCB (any DAC; not just Mojo). (**relative since although the connection itself is 'immune', it does not immunise the DAC circuitry from other avenues of RF intrusion, so an optically-connected DAC should not casually be assumed to be immune from RF intrusion)
I quoted some of Rob's comments on this topic, in the 'informative posts' section of post #3; a couple of which are as follows:
Can anyone pls let me know what does mean by "......USB cables that have ferrites in the cable is a good idea ....."?
From where i can buy such a cable?
Pls help me?
yes, it means a cable with one of these ferrite bands around it:
https://www.amazon.com/eBoot-Pieces-Ferrite-Suppressor-Diameter/dp/B01E5E5IY4
Some cables already have one fitted, others can very easily be fitted with one, manually, as they just clip-on
