Xcalibermj
- Mar 17, 2016
thanks alot. What differences have you noticed using that cable?
Convenience for starters. Sounds better than cheap otg connectors supplied with mobiles. Worth the $29
Sound qualities did improve BUT for me, it was at the cost of transparency. It was like a veil had been added.
does it reduce the the emi static noise? Its pretty unbearable and really getting to me between songsConvenience for starters. Sounds better than cheap otg connectors supplied with mobiles. Worth the $29
My Mojo is about to arrive, meanwhile I've got an Anker PowerPort 5 and a PowerLine Micro USB (this one, 1.8m lenght https://www.anker.com/products/A8133011) for charging as suggested somewhere in this thread. Now, I would use Mojo also as a desktop DAC...how can I connect it to my desktop PC? Is it ok to use the PowerLine Micro USB cable or it's only for charging? The USB cable supplied with Mojo is obviously too short for this purpose.
Nice, would you be able to provide a link for the cable please?
Peon audio cable. Arrived a few days back. Works well.
@Mython I didnt know, just figured I'd try.
The ten hours applies if Mojo has been in long term storage and the battery is completely flat. So it won't apply now as units are only a few weeks old.
If the white light goes off, it is not charging.
Rob
At this point if any phone to mojo cable doesn't have significant RF/EMI elimination cababilities, i'm not interested. Who cares about sparkly highs when you hear beep, pop and hum the whole song . Shoutout to everyone in an office with poor reception and using a phone w/mojo.
Do you have your phone stuck on or close to your Mojo when listening?
Not meaning to play devil's advocate here but why not use a longer USB OTG cable and place it a few inches or feet away from your phone? If you've got a phone constantly rattling the sound looking for a signal when reception is bad then just switch it to Airplane mode and store some of your Spotify or Tidal for offline use. Hell I have unlimited verizon with my Nexus 6 and I still keep a few Tidal playlists offline just in case I'm stuck somewhere with no signal.
Not trying to step on any toes, just offering alternatives and workarounds.
