rkt31
- Oct 14, 2014
can anybody suggest a cheap dap with optical out for mojo ? fiio x7 and ibasso dx80 are expensive and lotoo paw is not available in India.
Please read the section entitled 'Connecting Mojo to OTG (microUSB) devices > USB OTG Cables for use with Mojo', in post #3, where you'll find several USB cable options (and a heap of other useful Mojo information).
The Forza Audio Works cable is a popular premium option (although I wish it had right-angled plugs, instead of straight ones, so that it would exert less leverage on Mojos microUSB socket)
Be careful you order a cable with the correct connectors on it, for your phone (I think S7 edge has a normal microUSB port, but do please check in case it's USB Type-C).
http://forzaaudioworks.com/en/product.php?id_product=55
(Click image to enlarge)
Seems to have no RF/EMI blocking capabilities. I'm currently im the market for a good microb to microb cable for my S7 edge as well-with built in and end to end EMI/RF shielding. I would think this would be the main selling point of a cable like this, who cares if the highs are better when you hear beep pop fizzle and crack all day. If anyone knows any cables that actually stop or nearly completely mute EMI/FR and are microb to microb, I would like to know. I'm currently attaching several ferrites but would prefer a more elegant and packable sheathed cable.
Is this any good?
https://www.moon-audio.com/silver-dragon-form-fit-usb-cable-by-moon-audio.html
Is this any good?
what is the "double layer shield"? I'd need to know more about that before I could say if it did anything for EMI/RF.
Stay updated on PlusSound at their sponsor profile on Head-Fi.
We offer shielded cables for IEMs, Headphones, and interconnects. Here's how it look like internally:
Unfortunately, your website doesn't appear to list anything like the type of cable I was referring to:
- MicroUSB - to - MicroUSB (for example, to connect an Android smartphone to Mojo)
- Lightning - to - MicroUSB (including an integrated Apple MFI/CCK chip) (for example, to connect an iDevice to Mojo, without needing a seperate CCK)
Micro USB connectors are currently out of stock, but we should have them soon.
As for Lightning to Micro USB, we have the MFI manufacturer license, and is something we are looking into.
