The good old days@kumar402 nope, but how typical of British Gents who thinks their timezone is the one to rule the world, I guess some habit from good old times of Great British Empire when ruling over seas and oceans![]()
yesI don't understand the negativity around Micro-USB. There is a USB-C input, and the Micro-USB connection is obviously for backwards compatibility with Poly.
you have to carry a micro-usb cable just to charge it, when everyone is using usb-c. usb-c also enables fast charging. new mojo is missing out. having said that, i still bought it.I don't understand the negativity around Micro-USB. There is a USB-C input, and the Micro-USB connection is obviously for backwards compatibility with Poly.
Usb c is just an interface. By itself It enables jack shiiiiiitusb-c also enables fast charging.
https://www.xilinx.com/html_docs/ip_docs/pru_files/v-uhdsdi-audio.html
On this document, UHD DSP seems to be relatif to only Ultrascale FPGA But it seems usable with Artix 7 too.
With Gofigure could we change the coefficients in the UHD DSP for equalisation with one interface USB of the Mojo2 or across the Poly?
40 years later, maybe I will restart to use an equalizer.
I’ve just got in from work. Here’s the summary at the bottom of the HFW review.
I was unfamiliar with the Gryphon so I just had a look at it. Yeah on paper it seems to have a lot more going for it. When price constraints are imposed on a DAC, that's not always a good thing. Smart though to wait for reports to come back. Both look like great options and I don't think anyone could go wrong with either choice.
Having said that, I think the eq feature in Mojo 2 is going to be a real difference-maker. That has a good chance of leaving much of the competition in the dust. I base that on how much folks here fiddle with different pads to try to get the sound they prefer from their headphones. Mojo 2 owners might not have to mess with such things going forward.
Any retailer advertising a pre-order pre-embargo is risking getting no stock at all. That would be rather embarrassing, having to refund all their customers.
You mean, I think it should have Bluetooth. I think, like someone else suggested, a Gryphon is a better option if you want Bluetooth, and I haven't tried it yet. Maybe when APTx Lossless becomes available... and if it is actually lossless and works reliably (I'm willing to best that most of the time it isn't lossless). Chord obviously have put their energy in the Poly and true lossless transmission using WiFi, though it has been something of a rough ride.
Here's what I think the logic is here:
You might ask, why not have both ports as they have with the data port, if they want to keep Poly compatibility? I'm willing to bet there's a reason preventing that, such as safety. There is always some idiot out there that will try and use both charging ports at the same time, maybe with a Poly connected, and fry the device, for example. Two ports may also not meet whatever charging specifications it is supposed to meet. Basically, a bad idea overall. Then, of course, between the minor inconvenience of having to use a micro USB cable, versus the major inconvenience of Poly customers being screwed over, I think the choice was pretty obvious.
Not to mention, the people who are genuinely upset at not having both ports being USB-C is going to be incredibly small in number versus the vast majority of people who don't care.
And the USB-C socket itself, other than being able to be inserted in either direction, brings zero benefit in and of itself.
Just catching up on the posts. I really liked the original Mojo. But if the rumours are true that the Mojo 2 charges by micro usb, I don’t care how good it might sound, it’s not on my list to buy. I only have one device now that uses micro usb and that’s a 5 year old Sony camera, that’s due to be replaced, and the replacement will have usb c. All my plugs are usb c, and it makes life so much easier. Here’s to hoping it will charge by usb c.
If by fast charging you mean QC or PD that was never going to happen as I understand it this functionality is part of the SOC in mobile phones etc.Fast charging would have been nice, but not having it´s no deal breaker for me.
The possibility to use usb c as well as usb micro for audio connection, is very nice.
Now i use audioquest dragontail/coffee usb a, to micro usb, since there is no usb c to micro usb wire.
So i appreciate the possibilty to use an usb c to usb c wire without the dongle, but i would have to buy a new wire.
Morning Rob,The Mojo UHD DSP is my own unique custom core, it's nothing to do with Xilinx IP.
Lack of balanced output should be in the advantages side; adding balanced outputs would degrade transparency with my DAC architecture.
Like most audiophiles I always hated tone controls or EQ, as they damage sound quality. This also applies with 64 bit processing (more on this later today). So having an ability to adjust tonal quality without it degrading sound quality should prove very interesting - I am intrigued as to how this will be accepted by users.
The intent was to put two charging ports in - micro and USB C. However, it was impossible to fit the extra USB C charging port - USB C connectors are quite large and deep.
You need to understand one essential truth for me.
Musicality/sound quality comes first.
Musicality/sound quality comes second.
Musicality/sound quality comes third.
Musicality/sound quality comes fourth.
Musicality/sound quality comes fifth.
Musicality/sound quality comes sixth.
Everything else is next.
If musicality is not your number one priority, look elsewhere. You will be inundated with choice.
It's very odd to need micro-USB to charge, I almost don't believe it, as it should be quite simple to have two charging inputs, both USB-C and micro USB. From an electronics perspective i can't see how that would cause any problems?you have to carry a micro-usb cable just to charge it, when everyone is using usb-c. usb-c also enables fast charging. new mojo is missing out. having said that, i still bought it.
Good joke. Typical british humorIf musicality is not your number one priority, look elsewhere. You will be inundated with choice.
