miketlse
- May 8, 2016
The Chord threads have many posts from people who cannot help fighting their corner, even in circular rooms.Meh. Whatever. People love complaining.
C'est la vie.
Sorry, I was replying to Paul!Yes, and I was merely having fun providing a response to the question - why.
So just one extra cable
For me it is an extra charger as well as I mostly use either a 24w or 96w USB-c charger when travelling, depending on if I have a laptop with me or not. Most adapters from C to A are not dimensioned for charging, just data so they are unsafe to charge on at the currents that the mojo 2 pulls.So just one extra cable
I have a couple of adapters where it explicitly says they should not be used for charging and 5v 2A is way above the 5v 0.5a that is the spec for a normal USB-A 2.0 port.Well, not quite. The Mojo2 doesn't pull huge power. It's not PD pulling 30-96W like the macbook pro pulls. The 5V 2amp is pretty tame. It's the data transfer that needs the higher quality cable. I use an anker 60W PD GaN charger when I travel because its powerful enough for thr MacBook pro to charge fairly quick, and 1/4 the size of the Apple brick.
+15V 0.5a is the spec for usb A from a computer/laptop USB A port. I've had dozens of 5V 2A USB A wall chargers with no name cables. Never had any issues. Except Astell Kern.
You missed my point. When I travel I would have to take a USB-C charger just for the mojo. So thank you Chord for not making it USB-C…The reason for the negative opinions is simple in my mind. This is without a doubt a portable, to go device for travel. And so one travels. And the Mojo comes with, right? So you take with you a very nice charger for USB-C for your phone, DAP, and anything else. With a nice, sturdy, long cable. But wait... for the Mojo you have to find that micro-USB cable. And wait, it's only 15 cm long, so you need to find good spot to rest the Mojo on at the end of that 15cm cable not knowing where exactly the hotel outlet will be at (disclosure: they are usually in terrible places). Will it be dangling mid-air? That won't work. Or do I keep the laptop on at the end of the day just to slowly charge the Mojo with this 15cm cable? No... I give up, let me go to Amazon and buy a longer micro-USB cable just because of the Mojo. OK, still not frustrated, maybe. But wait, now I travel 20 times a year, sometimes for a week, sometimes for a weekend, sometimes for a short work trip. Different backpacks and setups needed depending. And every-single-time, better make sure I have my special 1.5m micro-USB cable because.... thanks Chord.
That's the frustration with Chord releasing a charging by micro-USB-only device in 2022. For me.
An adapter is not what I wanna use when I've bought the device. Nor spend $ on one. Also adapters mess up sound.A simple adaptor would do the trick.
