Hypops
Also, some amps don't like a full 3V at their RCA input, so the lack of a dedicated line-level mode gives you some additional flexibility to better match your other gear. Worth also knowing that the Mojo 2's cleanest output range is about 3-4.5V, but even at 2-2.5V (more typical for RCA), there isn't that much more distortion. According to both Golden Sound's and ASR's measurements, there's only a difference of a few dB distortion between 4.5V and 2V.Hello! I can’t find in the manual how to run the Mojo 2 strictly as a DAC. The Mojo 1 had a line-level mode by powering on while holding down the two volume buttons. Is there a way to set the Mojo 2 to line-level mode? Thanks for any help.
I'd actually be curious if anyone knows (or if Rob Watts has said) why Chord's DACs output at 3V over RCA instead of a more standard ~2V.
