amarkabove
End of the month.Still no details or specs ?
But that would spoil the teaser campaign and one prefers to be teased rather than spoilt.Still no details or specs ?
Of courseThis is only an adapter at the end. No balanced connection.
$799. Since so many people have complained that Poly, as an accessory, shouldn’t be more than Mojo, this would correct that.Any idea about the price?
My guess is it would be close to the qutest in price.$799. Since so many people have complained that Poly, as an accessory, shouldn’t be more than Mojo, this would correct that.
For sure there will be some “leaked” images from distributors.End of the month.
DACs that are designed around dedicated chips, can employed double dac chips and then use their outputs to produce balanced output.No not really, well not in my experience anyway, others will argue yes it does.
Why is balanced a better topology?All things equal the balance is better topology BUT this doesn't mean a balance is inherently better than any SE. For example, the mojo's SE output outperform several "balanced" amplifiers.
Who told this?Why is balanced a better topology?
(In our case of headphone DAC/amps)
Is not the amplifier topology that is better. Is the concept of using balanced circuit and chain throughout your devices. Is not always better as I said but all things equal a balanced configuration from source to amp output using balanced interconnects will provide lower noise and will be immune to RF induced noise from cables. Do I think a balanced configuration will make a “better” mojo? Not really. So balanced is good but not always necessary. If the Dac and amp were separate devices I would prefer a balanced topology to have flexibility with placement for example.Why is balanced a better topology?
