Be very careful what you plug into that Mojo 2. My first Mojo 2 did a similar thing before it burnt out an IEM, luckly it was only a cheap (£80) that I could afford to lose.Brand new Mojo 2 owner, on day 2 of owning. Day 1 I listened with just my iPhone and iPad via Lightning OTG and USB C. Everything was working and sounded great. Day 2, today, my Poly arrived. Configured it and was using it all afternoon. Working great. Tonight, I was listening via Airplay to the Poly, and out of nowhere I started to hear a faint static from the right channel. I tried all the troubleshooting I could think of, but it keeps doing it. It's a faint static like noise that comes and goes every few seconds and only in the right channel. What really surprised and frustrated me, is that the noise remains even with no data or power connected to the Mojo. Just the Mojo alone, powered up, my headphones/IEMs connected, nothing playing, and a faint on and off static noise coming from the right channel.
I've already emailed Chord and am waiting to hear back. I wanted to post here as well to see if anyone has had the static issues occur then remain with nothing plugged in. I'm also curious if anyone has any other troubleshooting ideas. Below are all the things I've tried so far.
The static noise is consistent regardless of volume changes or muting the Mojo. So disappointed because it sounded so good
- Powered the combo down, waited several minutes, then powered it up. The static remained even before connecting to Airplay or playing anything.
- Powered everything down, disconnected the Poly, reconnected it, then powered it up. Again, static remains.
- Powered everything down, disconnected the Poly, connected the Mojo to my iPhone via an OTG cable. Static remains, again without even playing anything.
- Powered everything down, connected nothing to the Mojo except my headphones (that is no Poly and no data or power connection at all). Static remains.
- Tried different headphones/IEMs, each of which also has different a different cable. Static remains across every headphone, only in the right channel.
- Tried each headphone port on the Mojo. Static in both.
- Firmware updated the Poly to 3.2 (it was on 3.0 when this first happened). Static remains.
- Attempted to play different sample rate music via USB C so that the unit was switching between sample rates (44.1, 48, 96, 192). No change to the static.
- Disabled cellular on my phone. Static remains.
- Brought the Mojo away from any other cellular or Wi-Fi devices, connected only to headphones (no data/power connection and nothing playing). Static remains.
The Mojo 2 was replaced but I didn't bother to push Chord for the cost of the IEM.
