shashiga
- Dec 19, 2011
Thank you .. Hows the sub bass and sound stage.Well I'm using a Yanyin x HBB Mahina with the Mojo2 and love it. So if you have $650 to spare, why not try that one.
You might as well keep your HD598 and use the Mojo2 EQ to raise the bass level.Thank you mike for the quick reply. I'm using Sen HD598 and like the sound signature of this head phone. Want to upgrade the headphone with more of bass and wider soundstage. Is it possible to get the same from an IEM ? Pls suggest.
my budget is around $1000-1200.You might as well keep your HD598 and use the Mojo2 EQ to raise the bass level.
There are many iems out there with a V signature, that will boost the bass level - but you could instead get a neutral sounding iem, and use the Mojo2 EQ to raise the bass level.
People still need to know your budget - are you looking for $10, $100, $1000, or $5000 priced iems?
You could try the Beyer Xelento 2my budget is around $1000-1200.
Thanks a lot.You could try the Beyer Xelento 2
I have the AK version which preceded the Xelento, and have never felt the need to change them.
Sony IER-Z1R. Huge soundstage, amazing Sub bass and great resolution. It has the least compromises/trade offs of the IEMs I've owned and heard. For inexpensive, Timeless 7Hz. $200 worth spending to figure out if the IEM thing really is for you.my budget is around $1000-1200.
Campfire Audio Vega 2020 and to compliment them the aftermarket cable from cosmic cables https://www.cosmic-cables.co.uk/product-page/pure-silver-8-wire-iem For me this tamed the bass a tad and brought out loads of detail in the treble and the soundstage is greatly improved compared to stock cablemy budget is around $1000-1200.
Hi, purchased Mojo 2 recently and preordered Poly. Using 6 year old Sennheiser HD598. Friends pls suggest a best sounding IEM and Headphone to pair with mojo 2. Thanks in advance.
Usb cable to mojo2?Brand new Mojo 2 owner, on day 2 of owning. Day 1 I listened with just my iPhone and iPad via Lightning OTG and USB C. Everything was working and sounded great. Day 2, today, my Poly arrived. Configured it and was using it all afternoon. Working great. Tonight, I was listening via Airplay to the Poly, and out of nowhere I started to hear a faint static from the right channel. I tried all the troubleshooting I could think of, but it keeps doing it. It's a faint static like noise that comes and goes every few seconds and only in the right channel. What really surprised and frustrated me, is that the noise remains even with no data or power connected to the Mojo. Just the Mojo alone, powered up, my headphones/IEMs connected, nothing playing, and a faint on and off static noise coming from the right channel.
I've already emailed Chord and am waiting to hear back. I wanted to post here as well to see if anyone has had the static issues occur then remain with nothing plugged in. I'm also curious if anyone has any other troubleshooting ideas. Below are all the things I've tried so far.
The static noise is consistent regardless of volume changes or muting the Mojo. So disappointed because it sounded so good
- Powered the combo down, waited several minutes, then powered it up. The static remained even before connecting to Airplay or playing anything.
- Powered everything down, disconnected the Poly, reconnected it, then powered it up. Again, static remains.
- Powered everything down, disconnected the Poly, connected the Mojo to my iPhone via an OTG cable. Static remains, again without even playing anything.
- Powered everything down, connected nothing to the Mojo except my headphones (that is no Poly and no data or power connection at all). Static remains.
- Tried different headphones/IEMs, each of which also has different a different cable. Static remains across every headphone, only in the right channel.
- Tried each headphone port on the Mojo. Static in both.
- Firmware updated the Poly to 3.2 (it was on 3.0 when this first happened). Static remains.
- Attempted to play different sample rate music via USB C so that the unit was switching between sample rates (44.1, 48, 96, 192). No change to the static.
- Disabled cellular on my phone. Static remains.
- Brought the Mojo away from any other cellular or Wi-Fi devices, connected only to headphones (no data/power connection and nothing playing). Static remains.
Seems to be everything, at least that I have and can try. USB, Poly, even literally nothing connected all (just the headphones alone and the mojo powered up). Intermittent static with them all on the right channel.Usb cable to mojo2?
Try BT only from Poly with Mojo2.....
You may recall from a couple of weeks ago (or so) ... my MOJO2 was suffering from a consistent feint scratchy noise on the left channel. Many of you kindly offered suggestions.
Well, after contacting CHORD UK they put me in touch with the French country distributor (not the retailer) ... they asked me to send the unit to them. After a few days, they agreed to exchange my unit. I have now listened to it for a number of days, and the good news is that the scratching noise I heard before is not present on the new unit ... and nor is there any 'white noise' that other people are experiencing.
My chain is iPhone 11 > DDHiFi USB Cable > MOJO2 > headphones and IEMs.
I would go as far as to say that the SQ is better overall than the old unit ... but I am relying on my memory.
Top notch ... no problems at all now.@Charente, how has the replacement unit been since April?
What charger are you using?I still have the same problem when powering mojo and the phone in the same charger. I lissen to static. If mojo2 is on battery there is no problem whatsoever.
