Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Dec 18, 2022 at 3:55 PM Post #6,136 of 10,709
Possibly but odd that it's fine with Tidal on my iPhone in that case!
Different app obviously.
Various forums seem to be littered with queries that are about anomalies with Tidal and various gear, the comments always seem to come back to the same thing, it's a Tidal app problem not a gear problem. My observations are the same, it works flawlessly on some platform but not others.
Dec 18, 2022 at 4:39 PM Post #6,137 of 10,709
Seem to have sorted the issue - turns out I was due a MacBook software update. Brain isn't working today...thanks anyway
Dec 19, 2022 at 1:37 AM Post #6,139 of 10,709
Tidal has long term peculiarities with what it DRM policy will allow. I think the DRM differs slightly depending on whether you use hardware, or streaming, it via app, or try to save local tidal files offline. Read like more hassle than I had the motivation to explore deeper.
Dec 19, 2022 at 4:37 PM Post #6,140 of 10,709
Does the Mojo 2 require a specific OTG cable if using type C to C connection, eg from a phone with USB C port?
I use the original Mojo currently and can easily find type C to micro USB cables on eBay but not many C to C cable stating OTG.
Dec 19, 2022 at 4:42 PM Post #6,141 of 10,709
Dec 19, 2022 at 4:49 PM Post #6,142 of 10,709
I use one to ensure the phone initialises UAPP.
https://oidiosound.co.uk/interconnects/usb/fiio-lt-tc3
Thanks for the link, the cable is honestly overpriced though. I can find USB C to micro USB cables for very cheap on eBay for the OG Mojo and they work perfectly, but almost no USB C to C cables available.
I have a USB C to C ddHiFi cable which I used for a previous DAC and the build quality is worth the additional cost, but it's very short. I'd like a cable around 1m length.
Dec 19, 2022 at 4:52 PM Post #6,143 of 10,709
I have the DDHifi as well, tbh I'm not bothered about a few pounds when Mojo was 500.
It works well
Dec 19, 2022 at 4:54 PM Post #6,144 of 10,709
It works well
True, the issue is the length really. I suppose the easiest option is to keep using the micro USB port which is still there.
I'm also a UAPP user so this kind of cable is essential.
Dec 19, 2022 at 5:04 PM Post #6,145 of 10,709
Dec 19, 2022 at 5:58 PM Post #6,146 of 10,709
Regular Type-C to Type-C will work fine. You could also use micro USB Input (Type-C to Micro).
Dec 19, 2022 at 6:24 PM Post #6,147 of 10,709
Dec 19, 2022 at 7:28 PM Post #6,149 of 10,709
Thia ugreen cable works..I am using magnetic micro USB plug to avoid disconnection.
I do this as well. Super convenient.
I try to put these magnetic connectors on all my equipment that I rarely need to transfer data or have a separate charging port.
Dec 20, 2022 at 4:03 AM Post #6,150 of 10,709
I guess my next question is whether, putting EQ and crossfeed aside, is the sound upgrade worth an extra £300 upgrading from OG Mojo?
