AussieMick
Why the sarcasm and negativity? Can’t we just be nice?
Has anyone tested different connection cables between mojo 2 and source to see if it make a difference in SQ?
Yes absolutely, I had to return the FiiO cable. A few pages back I wrote a detailed description of the differences I could hear.I tried using my Fiio (usb c to lightening) OTG cable from mojo to iPhone, but found that the usb micro and apple adapter produces a better sound quality? Has anyone else tried any other variations to iPhone?
....then why do so many hear substantial sound and music quality improvements listening to a file on an SD card in Poly over a generic USB cable connection.Please include me and Rob Watts to those.
Mind boggles!
I don't know, but that is not necessarily due to a USB cable.....then why do so many hear substantial sound and music quality improvements listening to a file on an SD card in Poly over a generic USB cable connection.
It reminded me of a typical religious question:
- I don't believe in god.
- You don't? Then tell me who made the earth and the sky, you and me?
- I don't know.
- See, god exists!
Digital audio is immune to noise, it is digital, it is either on or off, flickering is irrelevant. Like Morse Code, only its existence and duration matters, a bit of hum on the signal, does not change the message, once decoded. And digital signal is not analogue really, they just call it digital!
Now Chord portable DACs can not afford the power drain, so have no isolation on USB input. So if there is noise on the USB input, although it would make no issue to the actual digital signal, the noise can creep into the ground plane of the device and affect the analogue section.
But it also requires another connection to the ground plane for this noise to have a current flow! A noisy player plugged into a Mojo, running on batteries and headphones, can not have a noise current flow on the ground plane, so the noise does it no harm - only if you use it as a desktop DAC connected to an amp. Now you have two connections to the ground wire, and noise may flow into the system.
At any rate, a standard USB cable always suffices.
Note that, standard phone chargers do not have a ground wire , so plugging in a charger while listening does not affect the device either.
In short, God may exist or not, we have no evidence for it - but as Keyser Soze said, I am afraid of him!
So there . . . .
yeah, as long as others don't judge that many users have a different experience in this area.I don't know, but that is not necessarily due to a USB cable.
- I don't know.
- See, god exists!
So there . . . .
But they are NOT carried over as an analogue signal!Since the 1's and 0's are carried as an analogue signal through the USB cable, it is possible that
it is prone to the same issues that other cables can have - such as headphone cables, interconnects....
regardless, just because there may not be fully convincing theoretical/scientific explanations
(although there is currently quite a bit) doesn't necessarily invalidate those that hear an improvement.
...you're welcome to that view but that's not my understanding, but regardless I go with what my ears are telling me.But they are NOT carried over as an analogue signal!
First you falsely say since " 2 + 2 = 22 " then you use that to come to a wrong conclusion!
Just look up the definition of an Analogue signal - it means a varying signal in concert to another , this is exactly what a digital signal is NOT.
It is either 0 or it is 1 - it is never 1.5 or 0.7 - even if noise causes it, it wouldn't matter, when it is above 0.6, it is assumed as 1 and when less than 0.4 it is assumed as 0.
Another example, you have seen old war movies in which two ships send signals by code using a handheld floodlight.
The two ships talk to each other, regardless of any sea mist in between! don't they? are you telling me if the light should dim a little occasionally, it can make a difference to the message being transmitted?
You made me watch that!...you're welcome to that view but that's not my understanding, but regardless I go with what my ears are telling me.
Did you watch the video I posted? If so, your thoughts?
Noise on a digital signal is irrelevant - so let it be noisy! It won't matter. You can even inject some if you like.Optical isn’t noise free at all. The send and receive chips for optical create their own noise, too. Have you listened to what Nuno Vittorino, Paul McGowan, Darren Myers, Garth Powell and others say on the topic of noise and measurement of such?
Is this the cable you are using ?+1.
There are significant differences between cables for mobile use, but that is related to length, connectors and aesthetics. The first two of those can have an impact on sound from a reliability perspective but not from a quality perspective, assuming the conductors are not made of damp string. The third factor can certainly have an substantial influence subjectively.
My considerations for a cable for a portable device is; short, right angle connectors and solid connection. I use a DDHIFI cable which was overly expensive for what it is but very capably fulfills my primary requirements.
